Hi Davy87nj ---
Hey, with a basic leveling kit I don't think you can go much beyond a 265-sized tire (most commonly a 265/75R16.) But talk to Jeremy at WeldTec, he can set you up with that info.
If you're going *taller* with your lift (which Jeremy might advise, based on your desires/needs), you can jump to the quite-commonly-used 285 size tire (which a lot of guys with both 2WD *and* 4WD use here on the forum. (That would be either a
285/75R16 or a
285/70R17, on 8" rims, with zero offset. (4.5" backspacing.)
Here's another recent thread that goes into a lot of discussion around ideal tire size/width/offset, and quite a few of the posters on there (myself included) are
2WD guys:
http://www.sportsmobileforum.com/for...5-a-18003.html
