Old 08-30-2010, 01:04 PM   #11
Silver350's Avatar
Re: Which tire?
VW: $248-$25 rebate at Kal-Tire until the end of the month. They have ample clearence, about 3/4 " at the tightest on a turn at the rear of the wheel well, suspension not compressed (with these springs, there ain't much compressing going on).
Check this out:
Old 09-01-2010, 07:52 AM   #12
JoeyNick's Avatar
Re: Which tire?
Michelin LTX M/S, load range E.
JoeyNick is offline   Reply With Quote
Old 09-01-2010, 08:28 AM   #13
Re: Which tire?
I have been doing a ton a research on what works for heavy trucks. And I keep coming back to the Hankook Dynapro MT (they also have and AT) all the user reviews say it is a 60k+ mile tire on a diesel goes great in the snow +for me in Colorado. I had a used set I ran for a short while (came with the rims I bought) and even with minimal tread they did go great in the snow. And were pretty quiet but one had a balance issue, but being used and not knowing the history of them the balance issue does not make me lean one way or the other. I also like that the MT tread is more of an all terrain tread than most MTs and more aggressive than most AT tires. Has anyone ran them for any amount of time?
Derek
https://WWW.COLORADOCAMPERVAN.COM
00 PSD EB Quigly being converted to a Colorado Camper Van top
73 ford e100 soon to be 4wd with a 4bt
72 bronco aod injected 351 4 linked arb f/r 38in swampers
72 bronco 302 c4 soon to be 4bt w/ 5speed 4 inch lift 33 swampers
81 cj 7 in pieces at the moment injected twin turbo 401
ktm 525 exc, 620sx,
62 caddy convertible waiting for me to install 2007 northstar
dsw4x4 is offline   Reply With Quote
