Originally Posted by Gh0ztkid21
Seams good but I'm a little afraid with the 6.0l now. If I did get it I would do the necessary egr and oil cooler so that hopefully the van would be good.
>>>EGR valve =
made it to the shop. (Very common 6.0 issue)
>>>Injector failed =
tow. (Fairly common 6.0 issue)
>>>IPR valve/HPOP issue =
tow (Can be a 6.0 issue)
>>>Fuel regulator =
made it to the shop. (Fairly common 6.0 issue)
>>>Vacuum booster =
tow. (Non-6.0 issue)
>>>Heater hose popped off and lost all coolant =
tow. Poor repair job by Ford. (Non 6.0 issue)
>>>SMB wire harness caught in fan, radiator destroyed =
tow. (Non 6.0 issue)
>>>Mechanic left screwdriver on engine, radiator destroyed =
>>>Wiring harness failed =
made it to the shop. (Common 6.0 issue)
>>>Bed plate gasket leak =
The IPR and HPOP issues were sensors. I think I haven't had any EGR, or oil cooler issues lately because as you can see I replace the coolant about every year. Also I started using cetane booster on a regular basis. I change my oil at every 7K miles, run AMSOIL and a twin filter system. I also use Hot Shot Secret. I've never had a turbo issue to date. What I don't like about the 6.0 is all the sensor issues that can go bad with no warning. If a sensor goes out, many times you'll need a tow unless you know what has failed, have the part, and can get to it. Being on a trail in the middle of nowhere is nerve racking at times. But any vehicle can break down. 100K + 6.0 = time to bullet proof as much as possible IMO. Hopefully it will go 300+ miles w/o a 6.0 failure after I'm done.
But you can also see that many problems I've had were not 6.0 related.
