-   Sprinter Chassis (http://www.sportsmobileforum.com/forums/f11/)
-   -   Comments about this option list? (http://www.sportsmobileforum.com/forums/f11/comments-about-this-option-list-20539.html)
IPT 10-25-2017 01:28 AM
Getting ready to pull the trigger...here is the list from the dealer.
I'm thinking I can do with out the electric step. I might see if I can get rid of the Becker and just get the other options of the package and save some cash. Open to other thoughts and comments.
**** OPTIONAL ACCESSORIES *****
X07 High Idle Variable Package $ 665
ED5 : Parametric Special Module
MT4 : Idle Control - Adjustable
X61 Driver Efficiency Package $ 1,520
E1N : Becker Map Pilot
FR2 : Rear View Camera
L16 : Fog Lamps
MS1 : Cruise Control
X30 Low & High Range 4x4 Package $ 7,495
T75 : Door mounted assist handles, driver & passenger
ZG3 : 4x4 High Range w/Low Range Transfer Case
X27 Additional Battery Package $ 380
E28 : Auxiliary Battery 100 Amp
E36 : Cutoff Relay for Auxiliary Battery
X22 Trailer Hitch Package $ 370
E40 : Trailer Hitch - Wire Harness w/7 Pin Connector
Q24 : Trailer Hitch
X13 Lighting Package $ 950
F46 : Headlamp washing system
LG0 : Head Lamps - Bi-Xenon - U.S.
F01 Swivel Seat Package (Fleet Only) $ 1,015
BE2 : Parking brake lever,swivel seat
SB1 : Comfort Driver's Seat
SB2 : Comfort Passenger's Seat
SD2 : Seat Belt Mount deletion
SR8 : Seat - Swivel Base - Driver
SR9 : Seat - Swivel Base - Passenger
SZ7 : Seatback Map Pocket - driver
SZ8 : Seatback Map Pocket - passenger
S87 : Driver's Seat Frame
S88 : Passenger's Seat Base
C04 Active Safety Package Plus with Parktronic $ 2,680
CL4 : Multifunction Steering Wheel
EZ8 : Parking Aid System FRT&RR
F68 : Exterior Mirror - Power/Heated
H21 : Windshield with Filter Band
JA5 : Light and Rain Sensor
JA6 : Collision Prevention Assist
JA7 : Blind Spot Monitoring
JK3 : I/P Cluster Pixel Matrix
JW5 : Lane Keeping Assist
LA1 : High Beam Assist
LD0 : Overhead Cntrl Panel w/2 Lamps
Y10 : First-Aid Kit
Y45 : Emergency Flash Light
AR2 Axle Ratio 3.92
CT1 Rear Spring Vibration Absorbers $ 127
D03 Roof - High $ 2,500
D13 Roof Rails $ 274
D93 Deletion of Cargo Partition (Standard)
E46 12V Power Outlet- Driver Seat Base $ 84
EN7 Audio 15 (Standard)
ES2 12V Power Outlet Rear Compartment $ 84
FF8 Overhead storage slot, front center $ 96
FJ1 I/P Hinged Lid-Center Stack Bin $ 85
FY7 3-Button Remote Control $ 33
FZ9 Keys - Two Additional Masters $ 111
H04 Heat Insulation for Front Compartment $ 170
H12 Fuel-fired pre-heater/booster (17,000 BTU) $ 1,021
H15 Heated Co-Driver Seat $ 260
H16 Heated Driver Seat $ 260
H22 Defroster - Rear Window $ 232
H88 Rear Heater Prep $ 370
HY1 Remote Control for Auxiliaray Heater $ 348
J51 Fuel Gauge, Optimized for AUX. Fuel Tap $ 66
K9V Additional Quantity DEF
L65 Lamps - Cargo Compartment
LB9 Illuminated Exits $ 138
N62 Bracket for aux. Alternator $ 427
T12 Sliding Door - Two Stage Opening $ 75
T16 Sliding Door- Right Side (Standard)
T57 Electric Sliding Step $ 979
T74 Assist Handle - Sliding Door $ 29
T85 Assist Handle-Left Rear Door $ 29
T86 Assist Handle - Right Rear Door $ 29
V43 Cargo Van Wood Floor (Standard)
VA7 Storage Net in Hinged RR Doors $ 116
W17 Fixed Window, Right Side Front $ 132
W70 Tint for Rear Windows and Rear Side Windows $ 127
W78 Window rear door and washers/wipers $ 391
ZH4 Downhill Speed Regulation for 4x4 $ 53
Subtotal $ 62,406
Bbasso 10-25-2017 04:17 AM
For what make / model van?
Fitz 10-25-2017 07:29 AM
The electric step on a 4wd Sprinter? If you truly use the 4wd you are asking for trouble as the step mechanism will be protruding from the underside.
I have never heard anything good about the Becker. We did the radio delete and installed an after-market unit with Apple CarPlay, very happy with that decision.
Any plans to install an after-market front bumper? If so you will loose the fog lights and most likely the headlight washers. Parking Aid is most likely a conflict also.
Any plans to install an after-market rear bumper? If so you will loose the trailer hitch. Ditto the Parking Aid comment above.
Curious why the additional battery? Is that something that your location in Alaska drives? I don’t see the need here in much-warmer CA, I used the under-hood space to install the dual ARB air compressor.
Not sure about the additional DEF capacity, would need to know more. I am averaging 1,400 mpg DEF with a bit over 4 gallons of capacity, I follow the practice of filling every 2,500 miles with no issues.
We have the heated front windshield and really like it. The wires are not an obstruction to visibility.
jrobe 10-25-2017 07:45 AM
I agree with Fitz. You are spending too much on the van by just basically ordering everything that MB offers. You are better off spending wisely on just the things you will really use and then saving the money for the build. For example, I wouldn't spend $950 on a headlamp washing system when you could rebuild the lousy stock suspension system for the same money. You would appreciate that on every bump you hit. You could say the same for the lousy MB navigation system and rear view camera that can easily be replaced with better and cheaper aftermarket products.
IPT 10-25-2017 01:07 PM
Good input - I'll post more later but I agree on the step - dealer through that on there. Ditton on the Becker, though I looked at the other options in the package and it only amounted to $250 so I figured I'd let it stand. I have considered the after market stereo and back up cam. It may make sense.
Yes, I would much rather have the heated windshield than the step for sure!
Good point on the bumpers. No plan for a front one, but maybe a rear. Sensors seems to make good sense for parking being that it is such a large truck. Oh, 144 High Roof Sprinter.
Dual batteries up here are common for extra power in the cold. Also lots of darkness in winter so maybe more use of interior lights. Also plan for a 12v cooler and since I run RC cars need an invertor to charge batteries. My upfitter felt it was a good option that was easily built off and expanded. I mentioned the RB components dual battery and he felt he could do better or the same for less. He's a marine boat builder now doing vans the past few years.
Good thoughts appreciate it.
For the stereo, what was the option delete? It comes from the factory with speakers, yes? Some of it is not plug and play so did you just do the entire system from the ground up including backup cam?
I should add I am all for getting rid of a few things and saving some money to put elsewhere.
Fore sure will have after market wheels and tires too.
Fitz 10-25-2017 02:07 PM
Mine is a 2016 so you will have to find out the specifics for your model year, but my van came fully wired for the stereo including factory speakers. The speakers in the doors were replaced and two were added in the back and a good head unit was installed as were both a front and back camera and a Viper security system. Satisfied customer.
IPT 10-25-2017 03:31 PM
Fritz is the Viper security tied into the stereo in any way or just free standing and in addition too?
Fitz 10-25-2017 03:43 PM
Separate installation, done at the same time by the same installer.
Brianjwilson 10-25-2017 04:22 PM
Factory stereo and nav delete for sure, if possible. I have it and I'm relplacing it. If you have (or will be adding aftermarket) backup camera I think the park assist is not needed. I have a 170" 4x4 with no rear windows and have no desire for parking sensors.
I think (could be wrong) that headlamp washers are part of the bixenon lights. The head lights are easily worth the cost either way.
I feel like rear windows and defrost/wipers etc is a waste of money too but that's just me.
You'll love the high roof though so I'd say good call there. ;)
IPT 10-25-2017 05:12 PM
THanks for the thoughts on the stereo. If you "opt out" from the factory stereo, does it leave you with anything or does it become a raw install (and does it matter to the installer)?
Headlamp washing is part of the "package" and if it works, will be good for up here. In the winter the road spray covers the headlights making them a lot less effective. The "if it works" part is important though :).
