-   General Sportsmobile (http://www.sportsmobileforum.com/forums/f9/)
-   -   Removing antifreeze from carpet? (http://www.sportsmobileforum.com/forums/f9/removing-antifreeze-from-carpet-20780.html)
4x4sporty 12-09-2017 08:55 PM
Any suggestions for removing antifreeze from carpet?
I moved my heat exchanger inside under my bench/bed and had a small drip in the hose connection that I didn't catch.
I have a spot that is soaked about the size of a 5 gallon bucket.
I do have a professional carpet machine to extract with but not sure what type of chemicals to use or if just soak with water rinse repeat over and over would be best.
Bbasso 12-09-2017 10:25 PM
Extract as much as you can first then use a 50/ 50 simple green shampoo with then rinse, last shampoo with a 25% tide powder is what I'd do, safe but time consuming.
TomH 12-09-2017 10:39 PM
I had some spill and never could get it out. I wound up removing and replacing the carpet.
4x4sporty 12-10-2017 11:04 AM
I found on a classic car forum a guy who contacted prestone and they recommend straight water.
I will let you know how it turns out.
4x4sporty 12-12-2017 08:59 AM
straight water over and over followed by a little simple green no oily feel and smells great
TomH 12-12-2017 07:21 PM
Is the carpet installed in such a way that it's easy to take out? If so, you could just soak it in a kiddie pool several times in a row.
joefromsf 12-12-2017 08:29 PM
You know what's in a kiddie pool don't you. :cool:
4x4sporty 12-12-2017 08:47 PM
Thanks for the replies. It came out no problem with straight water several applications and a simple green last application for good measure.
