-   Member Classifieds (http://www.sportsmobileforum.com/forums/f14/)
-   -   For Sale: 2001 SB E350EB, 4x4, Cruiser top, $52,000 (http://www.sportsmobileforum.com/forums/f14/for-sale-2001-sb-e350eb-4x4-cruiser-top-52-000-a-23147.html)
skiingjohn 01-09-2019 02:14 PM
8 Attachment(s)
Ford Van
o 2001 E350 from Ford to Quigley to Sportsmobile, never used commercially
 Never a daily driver, never rented, maintained to last many many years
o 80,900 miles synthetic oil changed every 3-4k mi,
o V10 engine, pulls up the mountain passes easily
o New transmission fluid at 69,000mi, diff fluids also checked and were good
o New brakes front and rear less than 15,000mi on them
o American Racing Mojave rims
o Wired for trailer
o Daniel Stern Headlight system
o Main gas tank 28gal
o Aux gas tank 26 gal aux tank currently not working, an electrical gremlin between Transfer-Flow digital gauge and pump at tank (pump is working) great for long hauling between destinations. Does not impact OEM fuel system
o Aluminess full build
 front bumper with storage good for chains, tow straps, easy install for winch; also includes hi-lift jack
 rear bumper with storage tow equipment, misc
 Baja box incredibly useful for grill, leveling blocks, tarps, camp chairs, tools, etc. also has hidden Rotoplex spare 2.5gal gas can
Yakima 2x bike rack included
 Roof rack custom built to hold solar panels and built around opening large enough for AC unit good for storing sunshade, wood, etc.
Thule ski rack included
o 3rd owner
o Cruiser Top
o Brackets for easy install of Fiamma Awning
Suspension
o Quigley 4x4 Installed on new van in 2001
o Custom Deaver rear leaf springs very durable, considered better than OEM
 Eliminates rear end sag and helps weight balance which helps steering feel
o Agile Offroad RIP Kit professionally installed by Dusty Dog Garage at 72,000mi
 New FOX 2.0 custom valved shocks, custom variable rate coil springs, steering stabilizer, bushings, sway bar improvement
 Improved handling on-road; minimized body roll
 Awesome for dirt roads absorbs wash board incredibly well
 New bushings and steering stabilizer tightened steering to a factory feel
Interior
o Completely gutted Sportsmobile interior and rebuilt by RVI in San Diego
o 2x seat belts on bench seat
o 6 3 standup height
o Bed can fit 63
o Upper birth for child(ren)/storage, could easily be modified to sleep additional adults
o Refrigerator - 4.2CF 12v/120
 Truck Fridge designed to bounce 1million miles down the highway in a semi
 incredibly durable, no maintenance required
 never an issue keeping anything cold
 never killed the batteries
o Full wood cabinets including large cloths cabinet
o 2x slide out food/spice cabinets
o Upgraded insulation, headliner
o TV/DVD
o Composite counter tops
o Cabinet/seat for cassette toilet
o Basement located where spare tire was; large storage area accessible only from inside van
Electrical
o 360watt solar power Blue Sky MMP controller
o 2x Group 27 AGM batteries installed in Fall 2014
 Designed for enough kWh to run fridge, heater, tv, stereo, lights, etc for 24 hours without solar (solar panels covered in snow)
 With typical use, batteries are recharged within a couple hours of sunup
o Wired for, and brackets available for an additional 4D battery which was overkill for our use but is available
o Large inverter with multiple 12v and 120v outlets throughout van, fuse protected
o LED lighting throughout
o Wired for microwave including fuse protection
o Wired for AC unit, vent/fan currently installed
o Solenoid w switch to start van on house batteries if van battery dies
Water
o 15gal fresh water capacity
o 6gal hot water heater new in 2015
o Interior sink
o Outside shower
o Outside tap for water bottles, dog bowls, etc
o City water connection & gravity filler
o Easily winterized
Propane
o 6gal propane tank more than enough for the length of summer, 10ish days in winter
o zero leaks across entire system during length of ownership
o LP connection for Coleman style grill
o 2 burner stove
o 16,000BTU Suburban furnace, rebuilt in 2014, works every time
 Have used in sub zero conditions kept the van warm all night
o 6gal propane hot water heater
A few dings and dents that have been touched up. Never ridden hard. Intended to last, and maintained to last many many more years. Going from 1 kid to 3 kids has caused us to need a larger unit. Great unit for highway miles and camping deep in the mountains or desert.
BroncoHauler 01-09-2019 02:38 PM
Someone is going to score a killer rig at a great price. I don't expect this will last long.
clicker44 01-09-2019 02:49 PM
Interested
PM sent!
The message you have entered is too short. Please lengthen your message to at least 10 characters.
neatvan 01-09-2019 03:17 PM
Beautiful van and good luck with sale!
I'm curious where the aux fuel is located since spare tire location is used for storage?
Plus, you have propane on driver side!
Any chance you could post a pic of tank locations?
simplesez 01-09-2019 03:25 PM
The transfer flow tank is in front of the rear axle. I know because I'm replacing the fuel pump in mine now. Fits nicely in that spot. They don't manufacture that tank any more sorry.
neatvan 01-09-2019 03:33 PM
Thanks. That seems like the ideal spot, which is often wasted. Good for weight distribution and keeping the spare tire storage.
bigdood 01-10-2019 10:40 AM
Damn, if only that had a 3rd forward facing seat
BroncoHauler 01-10-2019 10:44 AM
You might be able to fit a captains seat (maybe on a quick release base) but it would be right in front of the side barn doors. You may want to explore that possibility if its the only thing keeping from this rig.
mikracer 01-10-2019 02:58 PM
It looks like if the short cabinet was removed, you can fit a seat pretty easily. As Herb said, I would look into that if the setup otherwise fits your needs. Wouldn't cost much or be too much work to get it done.
skiingjohn 01-10-2019 04:41 PM
Yes, the 'short cabinet' is the box I made for the cassette toilet and is held in place with a few small brackets. It would take at most 5 minutes to remove and the flooring and cabinets below/behind match. We also thought on installing a chair in this location. There are also seat belts on the side facing bench where we put the car seat for the last couple years.
