Old 08-27-2014, 06:35 PM   #1
rallypanam's Avatar
New cutting board
Someday I'll add a flush mount stove.. As while I like having one inside, I don't use it much.
In the meantime, I came up with a way to make the stove more useful when not in use. As a cutting board.
Bought a cheap cutting board at the store, cut it down to size, then countersunk threaded inserts into the bottom:
Drilled holes in the stove top in corresponding location for small thumbscrew jobbies:
Lay some foam tape to prevent rattling:
Install newly sanded and oiled cutting board:
Now I have a nice cutting board that is removable if needed for cleaning, but generally will just live there.
Old 08-27-2014, 07:06 PM   #2
Re: New cutting board
Looks nice. What kind of stove is that Robb?
Old 08-27-2014, 07:38 PM   #3
rallypanam's Avatar
It's an Atwood 2-burner.
And truth be told, it wasn't totally my idea. SMB did a similar thing on the same stove on the van I'm selling:
Old 08-27-2014, 08:20 PM   #4
gcvt's Avatar
Nicely done.
Greg
New van: 2003 E250 EB10
Old 08-27-2014, 09:07 PM   #5
OK got ya. It's a fixed stove. Even a better job. I don't know if I would go to a flush mount. That looks great and has purpose. I keep a cutting board over my flush mount stove.
Old 08-27-2014, 09:19 PM   #6
alta825's Avatar
I like it - Thanks! Chalk up another good rainy day project...
2001 RB50 V10 Quigley- SOLD
Old 12-22-2017, 10:11 AM   #7
rallypanam's Avatar
After three years I discovered the weak link on this mod.. the hinge tore apart in Baja last month..
So I replaced with a new 1.75" 18" long stainless hinge, rated for some hundreds of pounds. Should be able to handle the additional weight of the cutting board.
Old 12-22-2017, 07:08 PM   #8
marret's Avatar
Looks good.
Chris
2008 GMC 3500 Quigley Weldtec 4x4 Savana SMB
marret is offline   Reply With Quote
