An online forum community for the owners, admirers and fans of Sportsmobile vans and Sprinters, new and old. Share photos, advice, discuss modifications, camping or buy & sell. Anyone who owns, has a passion for, or just curiosity about SMBs, come in!
This section is for project write up, identification of known issues, and their resolutions. This is not for asking questions, discussion of possible solutions, or anything other than "complete" subjects. [more]
Joined: Thu Jan 31, 2008 3:25 pm Posts: 897 Location: Baja Whenever Possible
Posted: Wed May 06, 2009 4:12 pm
Post subject: Re: DynamattingtheFridge and Rebuilding the Wall
Couple things. Based on experience, I'd recommend using Titebond on screws if screwed into wood products or similar. If holes are stripped out, toss a toothpick in the hole with glue and problem solved.
___________________ It takes a village to raise an idiot. You must live in a big city.
Joined: Thu May 03, 2007 4:28 pm Posts: 2180 Location: Turlock Ca
Posted: Wed May 06, 2009 7:37 pm
I added the reflectix stuff to thefridge and it made a difference in noise. The thing used to hum loudly and is now a bit quieter. The main problem was one screw vibrating against the cabinet. At certain angles it sounded like orbital sander running and drove me nutz. As far as heat the cycle rates dropped at lower temps but when its hot (100+) it still runs quite a bit. Maybe I expected more and was biased. I never really did a test to see before and after results. I still think it's worth adding it. Deminimis, didn't you find the door might be poorly insulated? BTW done the tooth pic thing and it is a good trick.
Joined: Thu May 03, 2007 11:17 am Posts: 94 Location: North Vancouver, BC
Posted: Wed May 06, 2009 10:35 pm
bryanlaws wrote:
What I was really surprised about was how loose thethe little "upper side tray" was. This is the little shelf that pretty much runs the whole length of the driver's side just below the penthouse top rail in the 50 plan. We don't keep anything heavy in there (headlamps, a deck of cards and a pepper shaker) but that whole thing was loose.
Joined: Mon Oct 01, 2007 3:24 pm Posts: 893 Location: Los Angeles
Posted: Wed May 06, 2009 10:40 pm
I put Reflectix around my fridge on Sunday because I thought it worked well for some of you. I used Super77 Spray Mount to affix it. I liked how easy it was to cut the Reflectix and easily attach it. I hope the adhesive stays tight.
I will be heading to Utah for a week so I will see how thefridge cycles compared to before. It was so loud coming on every few minutes. I will report back.
steve
___________________ '05 Ford V-10 4x4 SMB "50" White '00 Jeep Cherokee 4x4 Highly Modified '04 Jeep Grand Cherokee- wife won't let me modify it. :-( Does anyone really read this stuff other than surfgeek?
Joined: Sat May 30, 2009 8:13 am Posts: 16 Location: San Francisco Bay Area; Belmont
Posted: Mon Jun 01, 2009 6:24 pm
Thanks to everybody for the posts on this subject. I am a new SMB owner (bought used in January) and new to the forum. After reading about the cost and dubious value of the Dynamat, I also just used Reflectix on my fridge. I have a 2006 EB50 with the 2.7 CF fridge. Once I pulled thefridge, I noticed that thefridge already had 1/2" of closed-cell foam insulation already taped to the top, bottom and rear, but not the sides. I added an additional layer of the Reflectix all around (except for the bottom, for air movement) using adhesive-backed foil tape which can be bought at Home Depot for HVAC applications, and it fit like a glove back into the enclosure (I hope that I haven't closed-off necessary air movement at the sides). There was still plenty of air-movement room at the top. It was easy and the total cost of materials is probably less than $20. It took about 1 1/2 hours total. Thefridge came out easily: there are four drywall screws that you must remove on the front face of thefridge; on a black steel flange on the RH and LHS of thefridge face (with door open). Also, there is one screw on either side of thefridge where the heads are accessed inside the adjacent cabinets. These side-screws were a bit tricky to get lined-up to go back into the holes once I re-installed thefridge, but all-in-all, it was easy. I also noticed that like Jage's case, there was evidence of a contact between the enclosure L-bracket bolt/nut and the bottom of thefridge. I can see this causing quite a rattle. It appears that the SMB installers had already ground-down the nut-head to reduce this, but apparently not enough. I ground it down about another 1/8" using an angle-grinder, and wedged a thin slice of firm foam between the two to reduce contact further. I am a light sleeper and any noise from thefridge in the enclosed space of the van can wake me up so I am quite eager to reduce thefridge noise (as it is, we either turn thefridge off, or keep it at 1 at night). After some experimenting, I found that the majority of the noise was coming from not thefridge body/compressor, but rattling of the internal shelves. There is a plastic-coated steel shelf that has a folding tray that you can swing-up to allow for tall bottles, etc; this rattled quite a bit; I secured it using two strips of that double-sided Velcro tape (used to secure a roll of extension-cord, for example, found at HD). Also, the two flimsy clear-plastic door-shelves are loose in their slots and rattled. I affixed a couple of those fuzzy Velcro-dots (in many Velcro kits, they will have pre-cut, adhesive-backed circles of both the fuzzy (loop) and hook sides) to the back of each tray on each side. That let them slide firmly into the slots with no rattle. In the past I have also noticed that various hard food-items in these trays will rattle (like beer bottles, mustard bottles, etc.). I cut-out some of that cross-hatch pattern foam kitchen shelf-liner for the bottom of each tray to help mute this rattling, yet the cross-hatching still allows air movement through the tray slots. The net of all this is that thefridge is much, much quieter now. I can't say objectively that the Reflectix actually quieted the rattling or reduces the cycling, but it probably does somewhat, and probably can't hurt either. I think it was well worth the overall ~2 hrs of time invested. For those that don't want to mess with the Reflectix and removing thefridge, the 10-minute fix which eliminates 80% of the noise is Velcroing that swing-up tray and securing the door-trays. If you don't want to bother with the shelf-liner, you could use a few sheets of folded-up paper-towel in the trays, which convey the added benefit of absorbing spills as well.
Joined: Tue Apr 15, 2008 4:15 pm Posts: 411 Location: Carmel Valley, CA & British Columbia Coast
Posted: Mon Jun 01, 2009 7:30 pm
vwteleman- This is totally off topic But I just had to tell you that every time I see your avitar, I just start salivating like Pavlov's dog. That is one compelling photo!! Bill
___________________ 2008 RB 50 Pueblo gold, Diesel, 4X4, Aluminess NO2B
Posted: Mon Jun 22, 2009 12:13 pm
Bill,
Pender Harbour is certainly a beautiful part of the world. My Mom is from Powell River, and we still have family up there, so I know that road quite well. Do you have a boat in the water up there?
I now spend my ferry trips heading to another Pender, though. My inlaws live on Pender Island.
Enjoy your summer. Maybe we'll see you on the road some time (we'll be getting our van back in about three weeks!).
Users browsing this forum: No registered users and 2 guests
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
