Old 07-11-2012, 05:53 PM   #1
Zeta's Avatar
Rebolting Penthouse
In my ongoing (neverending?) effort to bulletproof the van, I spent the afternoon replacing the failure prone PH bolts with these neat shoulder bolts I found at a local supplier:
They are extremely strong so I expect them to last. Of course I had to remove the PH springs to take the load off the bolts. I made a hole in the rear plate that covers the anti-rattle spring and used a small come-along to release the spring tension:
(Who took these blurry pictures?!) Worked very well and keeping the come-long inline with the spring is a good idea.
The pivot bolts were easy to replace:
The front mounting bolts were a PIA if you have bratwurst fingers like I do:
That said, the existing bolts looked OK and probably didn't need to be replaced. At least I know how to do it now.
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 07-11-2012, 06:19 PM   #2
larrie's Avatar
Rebolting Penthouse
So what is the source of the shoulder bolts?
Larrie
Old 07-11-2012, 06:55 PM   #3
Zeta's Avatar
Rebolting Penthouse
http://www.boltdepot.com/Shoulder_bolts.aspx
Z
http://www.tomsinclair.net
'06 RB50 SMB Diesel
Old 07-11-2012, 07:54 PM   #4
Re: Rebolting Penthouse
C'mon Tom, you gonna tell us the size of the bolts you used, or do we have to measure our parts?
Old 07-11-2012, 08:34 PM   #5
Zeta's Avatar
My short term memory ain't what it used to be for some reason...but here goes:
2-Front mounting bolts 1/4"x 1 3/4" long
2-Pivot Bolts 1/4" x 2 1/4" long
Z
'06 RB50 SMB Diesel
Old 07-11-2012, 10:22 PM   #6
larrie's Avatar
Rebolting Penthouse
Thank you.
Larrie
89 Ford 2WD penthouse
Larrie
Old 07-11-2012, 11:13 PM   #7
I was able to find the same bolts at my local Fastenal but I never have been able to find the size for the electric top. Are they the same?
Old 10-28-2012, 10:36 AM   #8
moorefc's Avatar
Re: Rebolting Penthouse (without a come-along)
Here is one I figured out in remote desperation to repair a broken scissor bolt without using a come-along.
Use a strong piece of line to replace the come-along and tension the line with the top partly raised. Then you get a couple people under the roof, raise it and place precut 2X2's or equivalent under the 4 corners of the top. Tension is now off the scissor bolts and even the chain to spring. So this can be used to carefully re-tension the top.
Also the bolts I used were Grade 8, very hard. These should not wear out....
Pac NW and warmer places
1995 E250 EB 5.8 2WD on to a new owner
2006 E350 EB Elect Top 2WD
moorefc is offline   Reply With Quote
Old 03-19-2013, 05:42 PM   #9
Rebolting Penthouse
My pivot bolt just snapped.
Zeta - The length and diameter you listed above was for the shoulder bolts or for direct replacements of the smb bolts?
ImageUploadedByTapatalk1363736208.004942.jpg   ImageUploadedByTapatalk1363736215.771674.jpg   ImageUploadedByTapatalk1363736226.789155.jpg
Old 03-19-2013, 06:11 PM   #10
Zeta's Avatar
Both. Good luck.
Z
'06 RB50 SMB Diesel
