08-26-2014, 11:21 AM
Go Solar...fixed or Portable setup?
Hi All,
I'm in the process of going Solar and I wanted to poll this group on their thoughts of going with a fixed or portable solar setup. Peter from Sportsmobile is quoting me roughly 1300 for a 100 watt system by Zamp but I see that Amazon I can pick up a 160 watt zamp portable system for 755.
I would like to know what you think are the pros/cons of each and more so if you had any regrets of either going with one over the other. Thanks in advance!
08-26-2014, 11:58 AM
Re: Go Solar...fixed or Portable setup?
Heres a couple links to portable units on amazon. The Zamp kits are the most expensive and I don't know if I would spend that much on a portable kit. In fact, for the same price as some of these portable kits, you could get a mounted kit that can produce double or more the power. I don't have solar on my SMB, but was interested in getting a portable kit but never pulled the trigger. We mostly go for a weekend so I'm never in much danger of running out of juice on the house system.
http://www.amazon.com/Go-Power-GP-PSK-1 ... zamp+solar
http://www.amazon.com/Go-Power-GP-PSK-8 ... zamp+solar
http://www.amazon.com/Renogy-Foldable-S ... zamp+solar
08-26-2014, 12:02 PM
One option that is regularly suggested in the forums is have SMB prewire your van for solar. I had all the wires run, zamp added, and an external panel connector added when I had my van built a few years ago. I recently installed two 100 watt panels on top of my van (picked up on ebay for $353) and still have the option of another panel to plug in externally in direct sunlight scenarios.
08-26-2014, 12:36 PM
Originally Posted by tonyvoudy
One option that is regularly suggested in the forums is have SMB prewire your van for solar. I had all the wires run, zamp added, and an external panel connector added when I had my van built a few years ago. I recently installed two 100 watt panels on top of my van (picked up on ebay for $353) and still have the option of another panel to plug in externally in direct sunlight scenarios.h
Did the same. Having a portable unit adds one more thing to setup and tear down. I would recommend adding a permanent panel, free energy without ever having to think about it.
Callsign KK6GIY
08-26-2014, 01:51 PM
I also have a portable panel that rarely gets used. Top fixed panels are nice if you have the room (and the money). Having a light regulated smart charge is generally good for battery health more so than letting the batteries sit not fully charged. An alternator doesn't keep your batteries fully charged in most cases. My panels also keep the batteries topped while sitting on the driveway. But if you have access to shore power or store your vehicle out of sunlight it becomes a moot point.
I agree that a portable panel is something that take up space, is one more thing to setup & take down and portable setups are often targeted by thieves more than fixed systems.
08-26-2014, 02:31 PM
Like several others, I had SMB prewire the van and I added a solar panel later.
To me, a portable panel has several drawbacks:
- you have to store it when you are not using it.
- you have to drag it in/out
- it can 'walk' away when you are not around
A fixed panel has a couple of drawbacks:
- when you park in the shade you get limited power
- you will have to adjust the penthouse springs for the added weight
- hail (and other things) can damage the panel
08-26-2014, 03:27 PM
Yes Mike, other things
08-26-2014, 04:10 PM
I agree with Mike's list. Portable wasn't for us due to limited space to store it, we had a whole half of the roof that would always be empty, and there isn't much shade to be found in the desert. Adjusting the PH springs wasn't hard, just a little scary.
BTW, I put my system in (2 x 140W panels) myself. Cost for all the materials was about $1200.
08-26-2014, 05:16 PM
08-26-2014, 06:59 PM
My vote:fixed, you don't have to think about it, you can usually put a larger panel up top vs. smaller portable unit, constant charge when you aren't using the rig. Only drawback as others have said, when you park in the shade and when you travel to Alaska and park it for a few days running the fridge and an Engle fridge/freezer, the sun is too low to give you a full charge on a fixed panel...as I found out the hard way at 3am when my co2 detector started beeping at me and I had to pull the fuse.....I'm bringing my generator up there next time, plus I might add a small portable Zamp to angle towards the sun.
Thread Tools |
Display Modes |
Linear Mode
