Old 01-28-2015, 08:19 AM   #1
reelchef67's Avatar
rocker switch placement?
Hi Guys Im looking for some ideaas on where to put some rockers switches and a exterior led temp gauge that is same dimension as switch up front somewhere.
I cant seem to find any pics of switch setups..
Are there any pillar pods that fit ford 2002 van?
Old 01-28-2015, 10:12 AM   #2
JackTuppVan's Avatar
Re: rocker switch placement?
A pillar gauge pod http://www.amazon.com/Auto-Meter-Pillar ... B001U9EY2U
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 01-28-2015, 10:25 AM   #3
shenrie's Avatar
^^^ i love and hate those at the same time. its nice to have that visual and be able to monitor, but those pillar pods create huge blind spots on an already large pillar. Plus it tells wouldbe thieves that you have add ons that could possibly have a good payoff.
i value my view out the window (ive even thought about removing the grab handle there as well) and plan to build an overhead console like a lot of other members have done for all the switches and gauges i plan on having. id post a photo, but i cant remember which members have added those to their builds, sorry
Old 01-28-2015, 11:28 AM   #4
Pschitt's Avatar
Originally Posted by shenrie
... but i cant remember which members have added those to their builds, sorry
I do ! But I have no switch on it, just some space to store maps and front curtains.
As you shenrie, I don't like any equipment on the pilar. More than reducing view field, lights of gauge also distract the vision when driving in the dark.
@reelchef67 : if just for a switch and control light, why not installing it on the Dashboard panel Under the stiering wheel? It's easy to access to and easy to reach when driving... ;-) I've all switches of on board air and lockers and also controls of airbags there.
Old 01-28-2015, 11:31 AM   #5
E350's Avatar
Here you go, post 10:
http://www.ford-trucks.com/forums/12419 ... auges.html
Old 01-28-2015, 11:42 AM   #6
shenrie's Avatar
^^^ I like that much better than the pillar setup.
that one looks like it is made by autometer, part# is: SKU: 18018. first site i found it on listed it for 53 bucks.
Old 01-28-2015, 11:43 AM   #7
Pschitt's Avatar
^^^ ScanGauge is still much smaller...
Old 01-28-2015, 11:57 AM   #8
shenrie's Avatar
^^^ yep, and i have one, but depending on what year your van is will dictate how useful it is. with the 7.3 i dont get an option for egt's, so im stuck installing a actual gauge. theres a few other options not available to us 7.3 owners as well, i just cant think of them off the top of my head
Old 01-28-2015, 12:03 PM   #9
rallypanam's Avatar
Related but different question on gauges.. Previous owner had a combined EGT/Turbo Boost gauge added. Because it's a combined gauge, it's kind of hard to read and I'm thinking of replacing with two 2" gauges.
So the question is, is the wiring on gauges standard? Can I just reuse the old wiring and plug in two new gauges?
Old 01-28-2015, 12:25 PM   #10
shenrie's Avatar
^^^ you should be able to use all the connections on that one gauge for the 2 you replace it with. just keep in mind that along with the wiring (actual wiring for boost gauge is normally just for lighting) from the boost part of the gauge will be a hardline (what actually gives a boost signal to the gauge) that you cant kink. there are union junctions you can buy if you need more length for the hardline wherever you relocate it to.
