Old 02-21-2015, 03:15 PM   #1
Bee
Tell me what these are for.
Hey guys. Maybe you can help me faster than me researching. I pulled off the paneling of my 2006 E250 cargo Econoline and found these wiring harnesses. Can you identify their use? They're all behind the drivers seat.
Thanks.
Old 02-21-2015, 04:28 PM   #2
E350's Avatar
Re: Tell me what these are for.
Buy this Wiring Diagrams E-Series book on ebay for your model year van (as well as the Ford Workshop Manual E-Series Volumes 1 and 2 for your model year van):
Because I respect copyright law, this is the only scan I will post.
Hope it helps!
Old 02-21-2015, 08:18 PM   #3
FYI, as you might infer from E350's post, that area is called the "B-pillar."
Old 02-21-2015, 11:25 PM   #4
gcvt's Avatar
"JWA" would say the same
Greg
New van: 2003 E250 EB10
Old 02-22-2015, 05:21 AM   #5
Absolute he would! Without beating that horse more an EVTM is invaluable for anyone DIY'ing on their factory wiring systems. I've had the Workshop Manuals (which are physically h-u-g-e BTW) but didn't find them overwhelming helpful because often times they lay out a procedure which directs the reader to use a specific tool without alternative tools also listed. This is just me---some might find them very beneficial.
Under that same trim piece at the lower portion of the B-Pillar (behind driver's seat) there are a number of used and unused connectors which can be incorporated into a build out. These have power or control function connections that can operate factory-type additions or if you're clever can made part of various levels of simple or sophisticated circuits in the rear area.
As an example I installed a rear aftermarket heater using portions of the unused connectors and power available at that location.
LiamMobile
Shyll
Guster
Salmon
