Old 04-11-2015, 12:37 PM   #1
sbgrimm's Avatar
Solar panel mounting with VHB tape
I'm edging closer to mounting the new GO160 panel I just bought from Amsolar. I bought the Renogy Z brackets and 5952 VHB tape. My PH top has nice, flat areas for the attachment. But looking at the size of the panel versus the size of the mounting brackets I'm wondering if the VHB tape is up to the job. The bracket footplate is 3 7/8" x 1 1/4" = 4.8 sq.in. per bracket, x 4 brackets = 19.4 sq.in. total adhesive surface.
I've never used VHB. Is it really strong enough to hold that panel down at 75 mph? I could add some more brackets...
Also, these brackets make it hard to remove the panel, should I ever need to do that. Any other suggestions?
Bardo
Old 04-11-2015, 12:49 PM   #2
REF
REF's Avatar
Send a message via MSN to REF
Re: Solar panel mounting with VHB tape
These use that same tape, but are a 2 piece foot for easy removal.
https://rvsolarstore.com/index.php?rout ... uct_id=112
Old 04-11-2015, 04:24 PM   #3
Viva's Avatar
AM Solar sells brackets wherein you mount the foot, and then another piece mounts to the panel. The panel piece has a captive nut, and a thumbscrew goes through the foot and into it. Each foot has 2.5 square inches of VHB surface area, and as far as I know they haven't had any fly off. The arrangement allows for tilting up the panels for better sun angle, or just to wire them up, clean under them, or etc.
Still, I wanted a bit more VHB surface area (I mean, why not? I couldn't see any downside.) I also didn't want to worry about the galling of stainless to stainless (fastener to captive nut). And too, the pre-made holes in the AM Solar feet weren't at quite the right place for my install. So, I made up my own mounting pieces. Caveat is that I have not mounted them yet, however I did help a friend mount three panels to my former SMB (he owns it now) and we used similar pieces. He reports that all is well.
What I went with is some 2" x 2" aluminum angle (3/16" thick - although I think 1/8" would have been fine). Each foot piece cut from this is 3" long, thus each "foot" has 6 square inches of VHB area. So a panel has 24 square inches (vs. 10 square inches on the AM Solar mounts, which reportedly work just fine). Then I made a "knuckle" piece that attaches to the bottom lip of the panel and hangs down - those are 1" x 1"x 1/8" angle. The theoretical plan is to put a rivnut in the knuckle and then use a shoulder bolt through the foot and into the rivnut. Another version of a captive nut.
My idea is fairly similar to the "sticky feet" pictured above in function, but with slightly different details.
I was originally going to put the rivnut in the "side wall" of the solar panel, but upon close inspection I found that must be a "hollow" wall (because while the aluminum is around 1/16" thick, the wall is more like 1/4" thick. Hence deciding to go with a "knuckle" attached to the bottom horizontal lip (which is solid). I originally wanted to go with the sidewall rivnut to get the panels closer to the roof for sleekness factor, but then I did an experiment with the panels up on the roof and decided that might heat up my roof too much. With the knuckle the panels will be around 1" to 1-1/4" off the roof.
When we did my buddy's SMB, he made the feet out of 2" x 3" angle, with the 3" side on the roof - so even more area for VHB. That said, in a couple of of spots the whole 3" part didn't contact the roof fully, due to the PH not being perfectly flat. It was still very close (he filled in with a little bit of caulk in a couple of spots), but I think 2" angle will be a good balance of the factors (at least I hope so!).
Another plus to using a separate foot and panel bracket is that you can accommodate a rounded or slanted roof (I mean, you can have the angle of the panel independent of roof angle, if you want to, but placing the locations of the holes).
I didn't like the idea of having the panels basically permanently VHB'd to the roof (as in the case of Z-brackets), so that's why one or another two piece design appealed to me (same thing as you are noticing).
Like I say though, I haven't actually mounted mine yet, so the jury's out on how well it will all work in reality.
Old 04-11-2015, 08:03 PM   #4
I would like to see some airspace under the panel for cooling. Heat is hard on most solid state devices.
Old 04-11-2015, 10:30 PM   #5
Viva's Avatar
I did a mini experiment - just for a couple of hours. I had earlier set a panel on the roof and, looks-wise, having it close to the roof (3/4" gap) was nice and sleek. But, I wondered...
So, I set two panels up on the roof with spacer blocks. One at around 3/4" from the roof (to bottom rim of frame), and one at around 1-1/4". It was sunny and about 72ºF. After an hour or so I took measurements with an IR thermometer. The plain roof (white) measured 85º, the roof under the higher panel was around 98º, and the roof under the lower panel was around 107º. There was no difference on the ceiling inside, but I have to wonder if that would not show up after a day's sun (I only had the panels up there for a couple of hours).
Based on that, I decided to put the panels more like 1-1/4 to 1-1/2"" off the roof. I felt that with them lower it they might end up "heat soaking" my rig after a hot day (not to mention the panels not being as efficient when hotter -- the underside of the panel was also somewhat hotter on the lower panel although I forget the exact figures).
I imagine even more gap under the panels might be better, but on my particular roof it would start to look quite a bit goofier if more than 1-1/2" or so (subjectively).
This wasn't terribly scientific, although I tried to make the conditions reasonably consistent.
