I'm looking at getting a solar setup from Renogy Solar off Ebay. I was all set to pull the trigger, but then saw a note on the ad talking about it being a "positive ground" setup. They also sell a negative ground system, which is about $100 more. See below for the systems and the relevant wording about the grounding.
I'd be wiring this into a stock SMB setup, which has a 1500w inverter/charger, three batteries (315ah), and from what I've seen a standard 12v negative chassis ground.
The question is, if I'm wiring these into my existing 12v house system through a charge controller, does the grounding matter? (I assume it does.) Is the fix as simple as changing to a different controller?
Here are the Renogy systems I'm looking at, and their grounding notes:
Positive Ground System
http://www.ebay.com/itm/281061525755?_t ... EBIDX%3AIT
This is a Positive Ground Charge Controller. If grounding is necessary, it must be completed on the positive line. If the controller is to be used on a vehicle which has battery negative on the chassis, loads connected to the controller must not have an electrical connection to the vehicle body.
Negative Ground System
http://www.ebay.com/itm/Solar-Panel-Kit ... 461ed84ba8
This is a Negative Ground Charge Controller. If grounding is necessary, it must be completed on the negative line. If the controller is to be used on a vehicle which has battery positive on the chassis, loads connected to the controller must not have an electrical connection to the vehicle body.
