Old 05-12-2015, 06:24 PM   #1
dirtanddogfur's Avatar
2012 upfitter switches
Anyone have a wiring diagram for a 2012 E350?
In particular, I am looking for the location of the wires for the upfitter switches. There is a large bundle in my engine compartment but before I started testing each one I thought I might ask. No luck on google.
2012 E350 SMB/Quad Van
2021 Chevy Colorado ZR2 Bison
dirtanddogfur is offline   Reply With Quote
Old 05-12-2015, 06:52 PM   #2
mikracer's Avatar
Re: 2012 upfitter switches
https://www.fleet.ford.com/truckbbas/to ... g_v1-0.pdf
Is this what you're looking for?
Old 05-13-2015, 11:04 AM   #3
That one is for a 2014 but I have not looked in the spot where they indicate those blunt cut wires are. I will have to look when I get home.
Thanks for the info!
Old 05-14-2015, 10:03 AM   #4
No, the wires are not in the same place as the 2014. This is driving me insane.
I guess I just need to check everyone of the bundle that comes out in the engine compartment.
Old 05-14-2015, 05:45 PM   #5
outopawn's Avatar
Did your van come with the upfitter switches? If not the blunt cut wires will not be there. You need to also get the wiring harness that goes with the switches.
Steve
2006 EB Transformer SMB 4x4 Diesel PH F/R Aluminess SOLD February 2015
2009 EB E350 V10 Quigley - Non-SMB
2005 4x4 Excursion 6.0 Diesel EB Magnaflow Superchip - Bulletproofed
outopawn is offline   Reply With Quote
Old 05-15-2015, 10:52 AM   #6
The switches are there. I just can't find the ends. In fact, my back up camera is wired into the first switch.
Old 05-15-2015, 01:28 PM   #7
Try this...
https://www.fleet.ford.com/truckbbas/to ... l_v1.0.pdf
Edit: I see someone beat me...
Is supposed to be 2012 E-series specific
Firetrux is offline   Reply With Quote
Old 05-15-2015, 02:06 PM   #8
Thanks. Maybe I am blind but they are just not there. The other possibility is they are still taped into the bundle. That would be a little odd but not out of the question.
The other oddity is that the huge bundle of wires I can find is not in that manual.
I need that "hitting head against the wall" emoticon.
Old 05-15-2015, 03:34 PM   #9
outopawn's Avatar
The below comments are all over the internet.
"I don't feel so bad now. I got frustrated and took it to the dealer. It took two different technicians 30 minutes to find them and they had to break out the manual to make sure they were supposed to be there! LOL!"
Some have said they had to lie on their back and reach way up top behind dash cluster.
This is where the blunt cut are located in relation to the Relay box. So if you can locate that you should be able to find them if they are tape to the harness.
Steve
Old 05-15-2015, 04:09 PM   #10
vwteleman's Avatar
Which flavour?
