I have a 2006 diesel SMB. I have the triplite inverter. I believe I have an Isolator in the engine compartment.
Amazon sells RENOGY solar kits with 1,2,3 or 4 panels:
RENOGY® Premium Solar Panel Kit 400W Polycrystalline Off Grid: 4pc 100W Poly solar panel UL Listed+ 40A MPPT Charge Controller+ MC4 20ft Adapter Kit+ Mounting Z Brackets
here is the 4 panel kit:
http://amzn.com/B00HKLOL98
Is 4 panels too much?
It has brackets and wires and an MPPT controller, which I read is more desireable.
Is that all I need to connect the solar to the house side?
Where do the wires from the solar tie in?
Do I need AGM starter batteries?
