Old 06-25-2015, 06:39 PM   #1
LenS's Avatar
Just ordered 200w of solar - Project is Completed
Just (AND I MEAN JUST) ordered Renogy 200 Watts 12 Volts Monocrystalline Solar Premium Kit for $439.99 which was listed as $30 off the regular $469.99 price with free shipping.
Batteries on mouse died. Replaced them and chkd again....3 minutes later. The list price is NOW 479.99 for the kit with $30 of so it is $449.99!!!!!
So I did order JUST in time....literally!!!
2000 Chev Express Extended van
all lights are LED's with very low power draw
other draws are camera (2) and laptops (2) charging
Len & Joanne
The Green TARDIS
Old 06-25-2015, 07:11 PM   #2
Re: Just ordered 200w of solar.
2 bucks a watt? Is that good?
When I think about it isn't buxawatt a good panel term.
"What'$ that funny noi$e?
Vegasrandall is offline   Reply With Quote
Old 06-26-2015, 03:45 AM   #3
We'll have to add that to this forums lexicon!
I've encountered a few of those great deals that go away--Amazon seems good at that. One minute price is "normal", next its reduced considerably, click on it again in an hour and its back to "normal" pricing.
Some days it pays to watch those special deal pop up ads on a web site---seems to be a growing trend these days.
Good score on the solar----hope to hear how the install and experience in use goes.
Old 06-26-2015, 07:28 AM   #4
They also sell their kits on Ebay, and have a "make offer" option, so you might look there in addition to Amazon.
Old 06-26-2015, 10:41 AM   #5
Jeffrey's Avatar
Len, did the 'kit' include a controller or other accessories, or just the panels. Must have cause I bought two 100 watters from them for substantially less.
Old 06-26-2015, 11:22 AM   #6
LenS's Avatar
Renogy 200 Watts 12 Volts Polycrystalline Solar Premium Kit
List:
$290 two 100w panels (bendable would have been an additional $80 each)
$140 MPPT controller (PWM controller would be cheaper)
$35 12AWG 20' cables w connectors
$26 two mounting hardware kits
$491 Total ... listed individual prices
Got for $439.99 as the "Renogy 200 Watts 12 Volts Polycrystalline Solar Premium Kit"
Len & Joanne
The Green TARDIS
Old 06-30-2015, 08:53 AM   #7
LenS's Avatar
That was VERY fast. Ordered panels on the 25th at 5pm and today (30th at 9am) FEDEX brought the order!!
Two 100w panels received:
Have read that panels should be 2-3 inches off roof for heat dissipation. Was thinking of adding a 3/4"x3/4" section of aluminum square channel under the mounting brackets for more clearance. Now I'm not sure. The brackets and the frame will hold the PV 1.75" off of the roof. Comments????? Thoughts????
Len & Joanne
The Green TARDIS
Old 06-30-2015, 10:04 AM   #8
1der's Avatar
Len:
I have not installed my panel yet, so take this with that in mind. I would go with min 1" or better (I plan to use at least 1.5") clearance under the lower panel frame edge to provide air flow under the panel when parked. If you have three mounting brackets per long side of each panel, then the channel would work. Otherwise get some L-angle tall enough to provide better edge support and under frame clearance. Two mounts per panel edge is not enough, imho.
I am interested in what others have for clearance in their installs.
Old 06-30-2015, 10:18 AM   #9
larrie's Avatar
Good score on the system. Love the new avatar.
Larrie
Old 06-30-2015, 11:09 AM   #10
arctictraveller's Avatar
I just installed this same kit. I mounted it to two cross bars on my roof rack using two pieces of wood running from side to side. It seems plenty strong enough and is off the roof by a couple inches. The biggest issue is branches getting stuck under the panel, so i plan to make some type of deflector. I ran the wires through the third brake light hole in the roof.
Arctic Traveller
KC6TNI
2001 GTRV
Advanced 4wd
