Re: Charging House Batteries - Chevrolet Express k60 Alterna
I have a Ford, but I'm curious about something. If I'm reading this right, over 100 amps is potentially available to your house batteries during highway cruising. Is that after the engine/Chevy systems take whatever power they need? Do you tend to see your house bank actually getting this much?
I have a friend with my same V-10 and alternator (120 amp, IIRC). He has a Victron "amp counter' battery monitor on the house bank, so that can show amps in. I was curious, so we started his rig the other day and I watched the gauge. We did not go down the highway, although he "revved" and I didn't see any change.
He says he has seen 90 amps, but that day it showed around 40 amps. Now, this may be because his house bank is typically up at 80% or higher SOC (due to solar panels). So I don't think the batteries would take any more amps even if they were available. He has #2 wire and about a 15' one-way run to the battery bank. This wire size was chosen as the minimum that would allow him to fuse such that he could "jump start" his start battery from the house bank and still be within the ampacity rating of the wire (but it's close) (in his case it would have been hard to fit a larger cable). Of course if only using for charging, then there is only voltage drop to worry about, and no need to fuse such that engine starting currents won't blow a fuse.
I've never known how much the engine/systems "take" from that 120 amps, nor how much really can come to the house bank (presuming it was at a low enough state of SOC to take it). So I'm interested in that part of the equation.
