AC Blower Motor Issue
2005 E350 6.0. Looking for some diagnostic feedback.
Started the van, turned on the AC, drove 1 mile to the gas station - no problems. When I restarted the van, the AC blower motor did not work in normal or max AC. I flipped the dial through all the settings and it did work on "Floor" mode, but nothing else. 10 minutes later as I flipped through the settings again it worked a very brief time in normal mode, but then quit and has not worked since.
I can hear the AC compression kick in and cold air does come through the vents when moving, but the blower does not work in any setting.
Based on the previous owners docs, I see the AC blower motor was just replaced in Jan of 2015
Could this be a dead blower motor again or does this sound like a relay type issue?
