Old 10-02-2015, 02:34 PM   #1
AKSeeker's Avatar
Will a ScanGuage II work on a 2006 E350 6.0 L Diesel?
After reading other posts, I was about to order a ScanGuage II for my 2006 E350 6.0 L Diesel Sportsmobile from BulletProof Diesel. I called them to ask some technical questions and Andrew told me that he believes that there was a change of the signal pin in the 2006 OBD II Ford van connectors that prevents the ScanGuage II from operating properly (and same issue for using the Edge Insight CTS also). He said that the had a 2006 6.0 L Diesel Sportsmobile in their shop a few weeks ago and couldn't get the ScanGuage II to work, even with technical assistance from ScanGuage. Apparently this is only an issue with the 2006 Ford vans and not the Super Duty pickups. Has anybody out there successfully used a ScanGuage II on a 2006 E350 6.0 L Diesel? Is this just a programming issue? Is there an OBD II "plug adapter" workaround?
'06 Ford 6.0 PSD E350 4x4 RB50 Customized SMB w/penthouse, Aluminess Bumpers & roof playpen. All Diesel & Electric: Espar Hydronic Heat, Wallas Catalytic Hot Plate Stove, VitriFrigo 12v Fridge, Dieselsite & Amsoil Filtration,.. and my other RV is a BMW R1200GS.
AKSeeker is offline   Reply With Quote
Old 10-02-2015, 03:22 PM   #2
Re: Will a ScanGuage II work on a 2006 E350 6.0 L Diesel?
Well this certainly is timely ... My BulletProof unit is in the box waiting for me to install tomorrow afternoon (Due to street parking at the house, I need to store the van).
I just checked their webpage and as far as I can see there is no warning about not working on an '06 E350. Guess I'll find out tomorrow first hand if it works or not.
Sacramento, Ca
'06 E-350 RB-50 6.0 PSD 4x4
jfgarberiv is offline   Reply With Quote
Old 10-02-2015, 03:36 PM   #3
AKSeeker's Avatar
Thanks jfgarberiv and good luck! I'll be waiting for your results. Did you purchase the "pre-programmed for Ford 6.0 L Diesels from BPD? If not, let us know how the programming goes also (I don't have a teenager around to help me )
Old 10-02-2015, 07:40 PM   #4
Bellpilot's Avatar
I bought a preprogrammed one for my 2007 6.0 and it works great. You still need to tell it what you want it to monitor but the directions make it easy. Would not own a 6.0 without this guage, it has really helped when codes came up out on the road and when the turbo veins started to stick. I use it mostly to watch my oil and coolant temperature differentials.
2010 E350 6.0 4x4 EB 50 SMB
Old 10-02-2015, 08:28 PM   #5
Tapatio's Avatar
Using a scangauge II on my '06 6.0 PSD with no issues.
Callsign KK6GIY
Old 10-03-2015, 08:42 AM   #6
X2
Old 10-04-2015, 11:41 AM   #7
Originally Posted by AKSeeker
Thanks jfgerberiv and good luck! I'll be waiting for your results. Did you purchase the "pre-programmed for Ford 6.0 L Diesels from BPD? If not, let us know how the programming goes also (I don't have a teenager around to help me )
Sorry it took me a minute to get to you ... Yes, I got the pre-programned unit and it seems to be working fine (as the others have confirmed).
I used a BlendMount unit to place the ScanGuage above the rear view mirror. So far so good ...
Sacramento, Ca
Old 10-04-2015, 11:54 AM   #8
SixCardCharlie's Avatar
Do you need any probes to get any of the gauges to work?
2004 6.0 PSD
SixCardCharlie is offline   Reply With Quote
Old 10-04-2015, 01:55 PM   #9
I went with the stock set up right out of the box, so I don't have any additional probes. Keep in mind this means I'm not monitoring EGTs which would require additional work and equipment (and I'm not sure if this can be done with the SGII, might require an additional gauge of some type, I'm still learning what I have).
james
Sacramento, Ca
Old 10-04-2015, 05:09 PM   #10
dmeade0's Avatar
Is the model BlendMount you used a BSG-1000
David
05 PSD SMB_4x4 RB-50
dmeade0 is offline   Reply With Quote
