Old 06-27-2013, 05:41 AM   #1
4MacFam's Avatar
New SMB! How does your aluminess rack brackets fit penthouse
Of the few pics I've seen the brackets from the aluminess rack should fit smooth/flush with the sides of the penthouse. Mine isn't even close. Everyone has a 1/4 - 1/2 gap at the bottom and the bracket rests on the corner (crush point) of the penthouse. I'm concerned that overtime and rough trails that this will damage the penthouse roof.
We're on a little trip (first) right from SMB-North and will return there before heading home.
I can't see that this is a properly mounted rack.
Now the problem of how to fix it. New rack? If so more bolt holes in penthouse as I'm sure they won't line up. Plus I have a six hour drive one way.
One solution might be to drive out to aluminess and have them bend the brackets, but I'm guessing this would still cause a uneven load distribution of bracket to penthouse top/side. And possibly have the brackets continue to bend under load.
What to do? I also went around and checked the bolts and some just wiggle in place so they're doing nothing right now.
I also have a "bulge" in the penthouse about 6" long that sticks out over the drip rail about 1/4", but I might just be overly anal about the fit.
Comments and suggestions from all you bright forum people would be appreciated. (Even the dim witted ones might help)
Steve in Madison WI
2013 E350 EB, V10 6.8ltr
Toyo 285/70 17
Steven McKenzie
Madison, WI
2013 E350 EB-44, V10 6.8ltr
Toyo LT285/70 R17
Old 06-27-2013, 05:43 AM   #2
4MacFam's Avatar
New SMB! How does your aluminess rack brackets fit on your p
Here's some pics
Here's the bulge. Drivers side 18" before back
Steve in Madison WI
Toyo 285/70 17
ImageUploadedByTapatalk 21372333306.954092.jpg   ImageUploadedByTapatalk 21372333320.452802.jpg   ImageUploadedByTapatalk 21372333380.286091.jpg
Steven McKenzie
Madison, WI
Toyo LT285/70 R17
Old 06-27-2013, 05:47 AM   #3
Re: New SMB! How does your aluminess rack brackets fit on yo
That is not right at all. I've never seen an Aluminess rack fit like that. Bending the tabs might work, but with that much discrepancy between the tabs and the PH roof, the tabs might not be long enough after getting bent.
Was this a new rack and install?
Old 06-27-2013, 08:21 AM   #4
Gooseberry's Avatar
Re: New SMB! How does your aluminess rack brackets fit penth
Thats so not right and needs to go back for a full rework.
The SMB shop that did that work needs to have the employee fired and the QC guy hung from the rafters.
Old 06-27-2013, 08:30 AM   #5
Originally Posted by 4MacFam
...I also have a "bulge" in the penthouse about 6" long that sticks out over the drip rail about 1/4", but I might just be overly anal about the fit.
That PH bulge looks odd as well. That, along with the rack issue makes me wonder if the PH top isn't installed improperly. I can't imagine the PH top being made wrong (they come from a mold, right?), but one section shouldn't fit differently than other sections.
BTW, I completey agree with Goose that the installer should be fired, and the the QC person should have their eyesight checked. How could anyone let that install leave the factory is beyond me.
Old 06-27-2013, 10:23 AM   #6
audisnapr's Avatar
Having built my own I can tell you the PHT is not the same width at the front and back. Is it possible the rack needs to be rotated 180*?
Sent from my SGH-T999 using Tapatalk 2
4amRacing
audisnapr is offline   Reply With Quote
Old 06-27-2013, 10:41 AM   #7
ANZAC's Avatar
That looks wrong. I would talk to Aluminess. Agree the installers should never have let it go out like that.
Sportsmobile-less.
Old 06-27-2013, 11:01 AM   #8
Looks like they send out a rack for a Chevy van (they have a narrower penthouse) and the legs were simply bent out to fit the Ford roof.
Old 06-27-2013, 12:11 PM   #9
Gnarvan's Avatar
Send the pictures to Aluminess and get their opinion via a phone call with the experts. Send pictures to SMB-north and then get them on the phone and schedule the replacement/repair. That is not acceptable. Don't let then bend stuff to get it to fit. Make them replace the rack with the correct one and be very vigilant on how they repair the holes on the top to install the new rack. If the holes don't match up I'd be talking to them about a replacement top.
That is a piss poor job that will lead to long term grief if you don't get them to fix it properly
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-27-2013, 12:29 PM   #10
PS - seeing where the bulge is, it looks like it is a result of the edge being pried out by screws used to mount that rack. If the correct rack were installed, it would not pull the edges out at all, and that's exactly what is happening with the small rack. You will probably see the area below the other legs area, since they are all pulling outward on the edge, and fiberglass is a plastic so it will effectually deform with constant load.
Ford
fabtechmfg
The YURT
MKRyan
