Old 01-11-2014, 01:43 PM   #1
tallt65's Avatar
Help with understanding heat - as in furnace & water
I'm in the process of deciding what I want included in my build. Originally I was going to use propane for the furnace and water heater. A simple and familiar solution since that's what I have on my tent trailer.
After reading and researching, I'm a bit confused on other options. I should add that my SMB will be gas powered, not diesel.
--Espar has both a "Hydronic Coolant Heater" and an "Airtronic" furnace
--Suburban has a motoraid integrated water heater option. I think their only furnace is propane.
--Isotherm has a Slim Square Water Heater that uses either 110v or heat exchanger.
So here are my questions:
--If I want to go with something that utilizes an engine heat exchanger for both a furnace and hot water, what should I be looking for?
--Does that mean I need to consider three items: a heat exchanger, a furnace and a water heater?
--If the above is true, am I better to go with different manufacturers or a single manufacturer?
--And while I'm at it where does a "flat plate" fit into this equation?
Help, I'm in over my head.
tallt65 is offline   Reply With Quote
Old 01-13-2014, 11:33 AM   #2
dhally's Avatar
Re: Help with understanding heat - as in furnace & water
I can further confuse you!
We have a propane tank and a Propex propane furnace (not sure SMB offers this brand). We like it because it is quieter and uses less electric power than a Suburban type propane heater.
The Espar products run on diesel, most people only get them if they have a diesel engine.
A flat plate is a type of heat exchanger, usually used to transfer heat from the engine coolant to a hot water system. This system can produce hot water while the engine is running, and for a little while after shutting it down.
Any hot water system is subject to freeze-up in cold weather. People do various things to prevent freeze-up, like draining the system, blowing it out with compressed air, or adding food grade antifreeze.
I don't think there is an off-the-shelf option for cabin heating with engine heat, since the engine would need to be running.
2009 E250 RB 5.4L "SilVan"
