Old 06-28-2009, 03:30 PM   #1
Scepter water container fill solution
Not the best but it's much easier and faster than the collapsable jug or silly funnel routine.
Materials:
male garden hose end
female garden hose end
2 hose clamps
small piece of RV hose
5' of clear poly 1 1/4 hose
You don't need the hose clamp on the water can but I opted to have it snug up with about 2 turns. It's pretty easy insurance so you can walk away from it until it's done emptying.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 06-28-2009, 08:58 PM   #2
surfgeek33's Avatar
Re: Scepter water container fill solution
Awesome write up Saline! Will do the same with our Scepter Cans. Thanks for the post and pics!
"I do, cellularSTEVE" :o)
Old 06-29-2009, 02:12 PM   #3
charlie56's Avatar
Only one comment.
Make sure to place a towel under the can when it is on the countertop. The dirt on the can will act like sandpaper and scratch the top.
Learned the hard way.
... Charlie
KZ6T
Old 06-29-2009, 09:16 PM   #4
Yep...been there and done that. Good point.
Old 06-29-2009, 09:18 PM   #5
BTW a good wax makes it look...well almost like new.
Old 06-30-2009, 03:01 AM   #6
I like adding quick disconnects which makes the whole process a lot easier:
viewtopic.php?f=13&t=271
2006 RB50 6.0 Diesel
SMB 4WD
Amsoil
Old 07-01-2009, 12:04 AM   #7
Be aware, I tried two different quick connects and both leaked. I believe that they are designed to be leak free only under pressure.
Desert Solitaire
2003 7.3L EB 4x4
Old 07-02-2009, 03:31 PM   #8
Try quick connects for aquarium pumps. I have them and they even have a gated valve on the connectors.
