Old 06-09-2012, 06:00 PM   #1
Tapatio's Avatar
External water pump mod
Having extra water cans is great but it's a PITA to fill the SMB tank. I decided to add a ShurFlo water pump so I could fill the tank via the city water connection. Runs off of the cigarette lighter port in the cab.
Callsign KK6GIY
Old 06-09-2012, 08:05 PM   #2
Re: External water pump mod
very cool bro!
Old 06-09-2012, 10:21 PM   #3
Nice!! I could use that set up.
Did you make the bracket?
What model pump did you use?
DonSt is offline   Reply With Quote
Old 06-10-2012, 09:10 AM   #4
Tapatio's Avatar
Yes, I made the bracket. Same pump that SMB uses, SHURflo 4008-101-E65 3.0 Revolution Water Pump. This way I can swap it if the interior pump breaks.
Callsign KK6GIY
Old 06-10-2012, 09:28 AM   #5
Thanks for the Info. This would really solve a problem for me. When I am in the same place for a week or so, I hate to move the van just to get water. Also, it would be an easier way to put in disinfectant, antifreeze, etc.
Do you leave the hoses connected underneath and just strap them to something or do you remove them after you pump in water?
Old 06-10-2012, 10:01 AM   #6
Tapatio's Avatar
I store the hoses in the rear door compartment. The pump comes with 1/2" hose connectors. I put 1/2" PVC end caps on the pump inlet/outlet to keep stuff from getting inside. I also have a Shurflo strainer on the inlet.
Callsign KK6GIY
Old 08-05-2023, 02:23 PM   #7
Anyone know the manufacturer/part number for the fill port? My 20 yr old one has sprung a leak. Thx
JeffO is offline   Reply With Quote
Old 08-05-2023, 04:42 PM   #8
KTMRIDER's Avatar
Are you looking for this?
https://shop.fieldvan.com/shurflo-city-water-inlet/
KTMRIDER is offline   Reply With Quote
