Old 02-13-2014, 09:47 PM   #1
hydroboost brake question OBS ford vans pre 1991
Did ford put hydroboost brakes in the OBS vans? Just found one in pick n pull with hydroboost/its a 1978? think I'm gonna pull it...help..info
E350MAN is offline   Reply With Quote
Old 02-15-2014, 12:29 AM   #2
Shocker's Avatar
Re: hydroboost brake question OBS ford vans pre 1991
Here is a good read on Hydroboost.
http://www.4btswaps.com/forum/showthrea ... Brakes-101
Shocker is offline   Reply With Quote
Old 02-16-2014, 02:08 PM   #3
Thanks good info...I pulled the unit...Im sure a previous owner installed it...it was on a 1978 E250......so its going to save me a lot of investigative hassle...i pulled the hydroboost/master cylinder/power steering pump and all lines...$77.00.....even if replace some of it...it was worth it just to get part numbers etc...
Old 04-13-2014, 11:12 PM   #4
you should share the part numbers ya know...
mwilliamshs is offline   Reply With Quote
Old 06-28-2014, 05:08 PM   #5
Hydroboost came off of a 1978 Ford Thunderbird
