Old 02-17-2014, 07:11 PM   #1
Completed Van Sportsmobile Pictures
[/attachment]These are some pictures of our completed Sportsmobile. We made it back from California with the exception of having a stop in Arizona to get a new turbo installed with only 40,000 miles!! I don't know why, seems early for a turbo to go bad. Does anybody have any idea what a good engine coolant would be to use or should I stick with ford gold. I plan on doing a full radiator and engine flush. Also, thinking about installing an edge insight CTS monitoring system. Thanks in advance.
tchief is offline   Reply With Quote
Old 02-17-2014, 07:53 PM   #2
Zeta's Avatar
Re: Completed Van Sportsmobile Pictures
http://www.evanscooling.com/assets/pdfs ... 4Apr11.pdf
Anyone use this stuff?
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 02-17-2014, 10:07 PM   #3
Originally Posted by Zeta
http://www.evanscooling.com/assets/pdfs/6-0L-Ford-Powerstroke-Evans-Install-Procedure-ver-04Apr11.pdf
Z
I researched that Evans waterless coolant when I did my EGR/Oil Cooler repair. Looks like some pretty awesome stuff, but I didn't put it in because I wanted the ability to top off with water in an emergency. There's a whole procedure to get the water out and apparently you have to make sure it stays out.
After a flush with Fleetguard Restore to get all the MC Gold out of there, I put in the Zerex "Extreme" EC-1 stuff. Silicate free and NAPA carries it.
If you're messing with the cooling system, you should add a coolant filter.
Old 02-17-2014, 11:11 PM   #4
Tapatio's Avatar
Congrats, silver SMB's are the best.
Callsign KK6GIY
Old 02-17-2014, 11:22 PM   #5
I highly recommend Zerex CAT/Cumins Extended Life Diesel coolant (EC-1). Ford gold is ok as long as you replace it regularly.
Be sure to keep green out (Quick-lube places always top off with green), or you will end up with Tapioca plugging up your oil cooler. Even the "Universal" coolants do not belong in the newer EGR-equipped diesels.
Old 02-18-2014, 09:04 AM   #6
Xerex G-05 is widely available and compatible with Ford coolant. Be sure and run a coolant filter and monitor oil/water temperature delta.
Old 02-18-2014, 02:50 PM   #7
What is the big advantage of that Mike other than it's compatible with the Ford stuff?
Old 02-18-2014, 04:24 PM   #8
It's the same stuff, just widely available. Probably cheaper than from a Ford dealer.
Old 02-18-2014, 07:50 PM   #9
Re:COOLANY/ANTIFREEZE
Has anyone ever used an antifreeze called maxsafe it is supposed to be aluminum compatible and it is a oat coolant and does not contain silicates,phosphates etc. Thanks to everyone who replied
