Old 05-21-2008, 04:12 PM   #1
jlrray's Avatar
Send a message via ICQ to jlrray Send a message via AIM to jlrray Send a message via MSN to jlrray Send a message via Yahoo to jlrray
Air Down Pressure?
What pressure do you guys air down to for different roads? For those that don't have compressors built in -- how do you air up again?
Joe
jlrray is offline   Reply With Quote
Old 05-21-2008, 04:53 PM   #2
I believe the air down pressure depends upon your normal psi. Different size tires have different psi ratings. Also, it depends on the terrain and how fast you will be driving. For what its worth, I'm still running the stock 245/75/16 tires that came with the SMB. I run them at 80psi on the highway. I've aired them down to 35 psi off road, but never went faster than 25 - 30 mph that way.
I use a Viair portable compressor to the air them back up. It has worked great and is pretty comparable in peformance to the onboard compressors. I have a prior post about this in the 4x4 forum.
Old 05-21-2008, 05:37 PM   #3
yvrr's Avatar
We are running 285-75-R16 tires at 55 psi on the highway. Off-road, I typically air down to 35 psi...this was arrived at through trial and error on the washboard roads in Baja. At that pressure, I'll drive at 35 mph, assuming that the road is safe at that speed of course. We have a frame-mounted Extreme Air compressor to air back up.
Jack
'01 Ford EB50p Quigley 4WD
Old 05-21-2008, 05:39 PM   #4
scatter's Avatar
There are already extensive posts on this subject elsewhere in this Forum. Use the search option and check 'em out.
Scatter
2007 RB50, 6.0
K1WGB
Old 05-22-2008, 01:41 PM   #5
John and Dana's Avatar
Joe,
Overland Journal reviewed portable air compressors in the latest issue. If you are shopping for one it would be worth picking up a copy. You can purchase from their website www.overlandjournal.com.
John
Old 05-22-2008, 10:34 PM   #6
jlrray's Avatar
I'll give that journal a try.
Joe
"Campy"
campy
The Toaster
CaptainG
