Old 06-02-2014, 08:03 PM   #1
buckkiller's Avatar
So you want a V10
This is out of a 74k mile f250 stick....weak valves!
Buck
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Old 06-02-2014, 09:56 PM   #2
ANZAC's Avatar
Re: So you want a V10
Some detonation there maybe?
Sportsmobile-less.
Old 06-02-2014, 10:44 PM   #3
E350's Avatar
What is that?
I don't know what injector nozzles look like on a V-10.
Old 06-02-2014, 10:47 PM   #4
Originally Posted by E350
What is that?
A paper weight. An expensive paper weight.
Old 06-02-2014, 11:45 PM   #5
E350's Avatar
buckkiller, am I seeing it wrong? Is there a 3/4" long item stuck in top of the piston like an arrow?
I do find it interesting that the piston tops are flat? 7.3L diesels have a toroidal depression in the piston top but the heads are flat.
Do V10s have a hemi head to go with the flat piston head?
Old 06-03-2014, 10:01 AM   #6
Tracker926's Avatar
I too am wondering what is that stuck in the piston? Looks to small in diameer to be a valve stem.
Tracker926 is offline   Reply With Quote
Old 06-03-2014, 10:04 AM   #7
dhally's Avatar
http://www.sportsmobileforum.com/vie...hp?f=39&t=1157
2009 E250 RB 5.4L "SilVan"
Babe
Babe
Vandemic
Charliesmom
