Old 07-21-2014, 04:02 PM   #1
SierraHawk's Avatar
Mounting a roof rack to the penthouse top
I have a low profile roof rack that I want to install on my PH top.
Should I drill through the roof and put a nut on the inside or can I screw the rails directly to the plywood ridges?
Are there any suggestions as to what kind of screw or well nut I should use?
Anyone know how thick the plywood strips on the PH roof are?
Old 07-21-2014, 04:38 PM   #2
mikracer's Avatar
Re: Mounting a roof rack to the penthouse top
Check this thread for ideas...
http://www.sportsmobileforum.com/viewto ... 13&t=11833
If you decide to go with the rails, be sure to install them in a way that the holes you drill are "outside" of the canvas. That way if the holes leak for any reason, it wont leak to the interior.
Old 07-30-2014, 08:52 AM   #3
Quercus's Avatar
I just got all set to install a rack on mine, for a large thule cargo box. That's about 57 lbs of weight, so I put two barbell weights on the top to try it out. Not only was it harder to put up, I didn't like the wobbliness of the top.
I took the wrights down and laid the cargo box and bars up on top, and still did not like the way things felt up there.
I know that there are threads about tightening the PH springs to make raising the top easier, but in the end I decided it was not worth it. Taking the bars and raingutter mounts and such back to REI.
Quercus is offline   Reply With Quote
Betsy
darryldickie
Dodge
lugee
