Old 01-05-2015, 07:10 PM   #1
what wheels fit?
Anyone know what if any F series wheels would fit a 2011E350? Have heard different stories that some will some won't.. Just thought I would ask the pros.
chavez is offline   Reply With Quote
Old 01-05-2015, 07:22 PM   #2
Re: what wheels fit?
Only if you have 4x4 which uses the '05+ SuperDuty front axle and rear wheel adapters.
Old 01-05-2015, 07:37 PM   #3
BajaSportsmobile's Avatar
1997 and older 8 lug F-Series trucks will fit 2wd E-Series.
Old 01-09-2015, 06:10 PM   #4
Thanks fellas...
Old 01-11-2015, 03:35 PM   #5
What about dodge 8 lug wheels, found a deal on a set. Will they fit? Think its an 05 or 06 2500
Old 01-14-2015, 09:35 PM   #6
Not going with 4wd. Just gonna get the maxxlift and 17 inch wheels. Just don't know what will fit and when ordering online that's important. Where has anyone ordered wheels for a 2wd 2011 e350. What is the lug pattern ? And is there a specific hub size
Old 01-15-2015, 04:51 AM   #7
They will work if you use a 2 inch wheel spacer.
Old 01-15-2015, 07:13 AM   #8
As long as you don't have a full float rear axle. Some of the newer Wagons still ended up with full floats.
You can also have the centers bored out, which will allow a hub-centric fit. That's what I did for my new inner rear steelies (except they are GM wheels, for proper backspacing).
