Old 06-06-2015, 10:52 AM   #1
Bro
StarCool Auxiliary Condenser Fan Blowing Fuse
2006 Ford E-250 conversion. The under floor condenser unit became clogged with sand/gravel mud. Washed out the best I could, but the motor unit is locked up and blowing the fuse. This is a Starcool system with a Danhard condenser/fan unit. Has anyone run into to this problem and have a recommendation on how to proceed. I will be contacting SMB and Danhard, but I thought I might get some of your thoughts before proceeding.
Bro
Bro is offline   Reply With Quote
Old 06-06-2015, 01:31 PM   #2
Re: StarCool Auxiliary Condenser Fan Blowing Fuse
It has happened to me as well. Usually it's a rock in the bottom that freezes the blade. Make sure it's all clear in the cage. If the motor burned SMB might be able to supply a replacement. I can ask my A/C guy where to find a motor if SMB doesn't have them anymore.
Old 06-07-2015, 10:48 AM   #3
Check for damaged wires. SMB ran the wires on ours on the outside of the condenser box/grating.
When I got ours, the PO had run over some rocks and crushed the wires against the box. When the A/C was on, the body of the van became electrically charged.
Old 06-07-2015, 08:24 PM   #4
Bro
Thanks, I have cleared the fan blade area but I think the damage may have been done before I realized the problem. The wiring looks fine. I pass on the results after discussions with SMB.
Old 06-10-2015, 07:31 PM   #5
Bro
Danhard has configured a new shroud/fan assembly and it's on the way to me. Excellent customer service and the cost reasonable. If you need some help, ask for Mark
Old 06-11-2015, 04:53 PM   #6
That's good to know. Last time I talked with them they wanted nothing to do with the SC system
Old 06-12-2015, 12:42 AM   #7
Can you post a pic of the shroud you have now and the new one when you get it?
Old 06-29-2015, 08:29 PM   #8
Any news on this one? I spent the evening trying to clean my fan but I think the damage is done.
My fan will come on and run for about 2 minutes. Then, it starts to slllloooooowwwww down until it stops.
Getting the fan and housing off to have a look in there was a PITA. But while it was off I was able to spray some Frost King cleaner in there and get everything cleaned up nice.
I thought I had fixed it. At least the fuse didn't blow. But again, the fan just slowly dies.
Ultralite is offline   Reply With Quote
Old 06-30-2015, 02:57 PM   #9
I've been exchanging emails with Marco Valenzuela at Danhard today. He's been very helpful so far.
Hoping to see some of the requested pics too as I want to make sure Marco and I are talking the same part before I purchase...
Old 05-15-2016, 08:19 PM   #10
Update?
Just found this thread... having the same issue on my 2006 E250. Any resolution from the original post? Pictures?
Also if anyone can share contact info for a replacement fan that would be much appreciated!
Matt
2006 Ford E250 EB50 -sold
1986 Westfalia Weekender -sold
flashKaleo is offline   Reply With Quote
