07-27-2015, 05:45 PM
2005 E350 4x4 Wheel Lug Pattern
Is it possible for a Fresno built 2005 E350 Sportsmobile with 4x4 to have 8x165.1 (8x6.5) all around?
07-27-2015, 06:32 PM
Re: Urgent - 2005 E350 4x4 Wheel Lug Pattern
Yeah, that's how they come. The trucks are 8/170mm.
2011 VW TDI Golf for hwy fun
07-27-2015, 06:35 PM
Wow, was I ever misinformed. I had read several places that the axels were from the trucks and therefore adapters were added to the rear axles to match.
07-27-2015, 06:40 PM
Well if by Fresno-built you mean Sportsmobile West they ordered the van from ford. I can't remember exactly the years but most of the vans came with 8/6.5. So, they would also spec the front dynatrac D60 with the same lug pattern to match the rear. The rear is typically the OEM semi-float D60 with spacers to match the front wheel spacing width or WMS-WMS.
If it's a ujoint conversion then it would be 8 on 170mm since he uses axles from the F series.
07-27-2015, 06:51 PM
Yup, SMB West. Thanks for setting me straight.
07-27-2015, 07:16 PM
No worries. And you do probably have spacers but it's not an adapter in the sense that it changes the wheel pattern. They probably also stayed with 8 on 6.5 because not everyone goes with aftermarket rims so that matches the wheels that came on the van.
07-27-2015, 08:08 PM
Many converters (I do not have first hand knowledge for SMB West) use 8 x 170 F series on the front and rear wheel spacers that convert 8 x 6.5 to 8 x 170.
My assumption has been that this is the way SMB does it but I'm not sure.
I have a 2008 Advanced 4X4 conversion and it's 8 x 6.5.
I think Quadvan does 8 x 170 and Quigleys are either depending on how old they are.
If you are wondering about your van a cheap way to find out is to buy a cheap brake rotor at O'Reilly's or Pep Boys and see if it fits.......mid 2000's Chevy Suburban or Dodge truck fronts will be 8 x 6.5 and Mid 2000+ F250 Superduty will be 8 x 170.
07-27-2015, 09:56 PM
I was only referring to SMB West. Except for Ujoint I have no idea what the other converters use. Either way, it was my understanding that all stock vans from ford going back to the late 90s are 8 x 6.5.
07-28-2015, 07:41 AM
Re: 2005 E350 4x4 Wheel Lug Pattern
I have a 2004 E350 with SMB West 4x4 conversion. 8 x 6.5 all around for me. I have a Dynatrac D60 in front and a full float Dynatrac D60 in the rear.
07-28-2015, 08:18 AM
Correct.......but it's not uncommon for the 4X4 converters to use 8x170......IIRC Quadvan uses this lug pattern.
