Old 08-10-2015, 03:23 PM   #1
'99 Chevy Express: power locks stopped working
Is anyone on here familiar with the Express 3500? Mine is a Quigley conversion.
Last week the power lock feature (pushing the button on any of the doors to open them all) stopped working. I have checked the big fuse relay on the front right (facing) of the engine bay. And I've checked the fuse panel in the lower left of the driver's side.
Still can't find the fuse that controls the power locks. Anyone have any hints on where or what I should now look for? I was hoping there was another fuse panel I'm missing.
1999 Chevy Quigley 4x4.
Damian is offline   Reply With Quote
Old 08-11-2015, 02:05 PM   #2
Re: '99 Chevy Express: power locks stopped working
It should be the inside fuse panel. Did you find the fuse diagram in the owner's manual? It'll blow if a button gets held down too long (usually its one of the dogs, but my van also has a rear door switch and luggage sometimes pushes the button).
Old 08-11-2015, 02:14 PM   #3
I don't see any fuses on the inside kick panel that says Power Lock Fuse or anything related. Is there any type of relay for power lock because I didn't see that either.
Yeah I also checked for stuck locks and didn't find anything. Nor did I find anything pushing down on the lock buttons on any of the doors.
Old 08-13-2015, 11:35 AM   #4
Here is my van and the two fuses boxes I have found. One is on the lower left inner driver's side. The other is the right side (facing) engine.
Old 08-17-2015, 09:37 AM   #5
I got it fixed. Turns out it was the 25 amp Accessories fuse which I swore I had checked once already. Oh well, at least it's fixed now.
Old 04-15-2021, 01:26 PM   #6
Thanks. I wasn't looking for a fuse labeled accessory. Turns out someone had replaced fuse with a ten. Apparently it lasted at least 5 years
manicmechnix is offline   Reply With Quote
The YURT
MKRyan
#G0nz0
rumrunner73
