Old 08-14-2015, 11:41 AM   #1
AC fitting thread repair?
The male threads on my AC cooler (99 Express 3500) are bunged up and I need to find a die that I can use to repair these threads. I've already tried O'Reilly and Car Quest and they only have a 5/8" size.
Anyone know where I can buy or rent a die that will repair these threads or even what size/pitch these are?
1999 Chevy Quigley 4x4.
Damian is offline   Reply With Quote
Old 08-14-2015, 11:54 AM   #2
Zeta's Avatar
Re: AC fitting thread repair?
If there's anything left, you can try a thread file: http://www.ebay.com/itm/Jawco-1-Nu-Thre ... 58&vxp=mtr
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 08-26-2015, 11:32 AM   #3
That looks like a male insert o-ring braze-on fitting. You *might* be able to heat that up and remove it, then braze on a new one. I went through a similar problem on my 98 Express 3500, but I had broken a connector completely off. I found new ones here:
http://autoacfittings.com/5-8-Tube-x-Ma ... IOB-10.htm
There's several different sizes available, so you would have to look for exactly which one yours is, obviously.
Good luck!
capn
capnkurt is offline   Reply With Quote
My Van
bfolens
ADVMOBL
Botchan
