Re: PH Top Crack
First, if it is a hairline crack, it is probably just in the gelcoat and not a structural problem. It could, however, allow water to get into the top and damage the wood structure.
I don't know fiberglass well enough to suggest a solution. Either someone else will come up with a brilliant solution, or you can contact a boat repair facility that deals with fiberglass.
Second, if you can put a photo in your gallery, you can put it into a post. Open your gallery, find the photo and note the number of that photo. Click on 'photo' while making a post and put that number between the brackets. Done.
