Old 02-21-2014, 11:20 AM   #1
pinz712's Avatar
Heat Exchanger help on 6.0 2008
Any one with a 6.0 coolant heat exchanger willing to let me crawl under there rig to see how they ran the line to the back factory or home build, around San Clemente. Debating on passenger side inside frame rail but, the muffler is there.
How did you run the lines to the back?
pinz712 is offline   Reply With Quote
Old 02-21-2014, 11:33 AM   #2
Tapatio's Avatar
Re: Heat Exchanger help on 6.0 2008
Mine's on the inside driver's rail. Welcome to check it out if you ever pass through Huntington Beach.
I'll take a few pics in the meantime.
Callsign KK6GIY
Old 02-21-2014, 12:08 PM   #3
You could also look at a stock Wagon for inspiration. They have hard lines for the HVAC running along the outside of the body on the driver's side. You could probably even pull the lines from a salvage yard van.
