Old 05-22-2014, 04:38 PM   #1
propane hook up
Just thought I'd post this. I have posted my complete DIY van on my thread east coast build out. I had mounted a manchester propane tank under van in which my buddy who is a plumber attache line via black pipe from 2 stage regulator thru bottom of van into bed box with a manifold supplying each propane fed appliance. I have replace my regulator once already due to leak outside, Ive driven across country and many trips over last year aprox 15,000 miles. I felt the black pipe was too rigid and application causing stress to regulator. I was correct. I took it to an Rv place. They attached a flex hose from two stage to the black pipe and a mock up shield till i make a thicker gauge one. Pic doesnt show hose but thought if anyone else is doing it themselves they may want to go this route..Hope it helps anyone out there.
Cheers
Paul
All I need are some tasty waves, Lynnski, and I'm fine.
bodhi1960 is offline   Reply With Quote
Old 05-22-2014, 04:39 PM   #2
Re: propane hook up
sorry cant get pic to load but I think my point is made..
Paul
Old 05-22-2014, 04:46 PM   #3
Re: propane hook up
Got it
Paul
Old 05-27-2014, 10:27 AM   #4
dhally's Avatar
Re: propane hook up
Looks like a good modification. All the regulations talk about using rigid pipe under an RV, but the only thing I've ever seen is hose. Seems to work.
2009 E250 RB 5.4L "SilVan"
