SheepShagger - [Title Empty]
Login FAQ Search It
Register
Sportsmobileforum.com
An online forum community for the owners, admirers and fans of Sportsmobile vans and Sprinters, new and old. Share photos, advice, discuss modifications, camping or buy & sell. Anyone who owns, has a passion for, or just curiosity about SMBs, come in!
The time now is Thu Jul 29, 2010 2:58 pm
View unanswered posts
View active topics
Forum Rules
Please do not use this section, or any part of this site to publicly post or request information for the purposes of copying any manufacturers’ designs for the purpose of duplication.
You may post publicly photos and information for purposes of improving, comparison, issue resolution, or repair, you may also privately pursue such information- however blatant requests for and public posting of images and specifications for the express purpose of reproduction or deconstruction will not be tolerated and will result in warnings or suspension from the forum.
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Author Message
Offline
PostPosted: Thu Jun 05, 2008 5:01 pm   Post subject: Home built 2007 Ford E150 van with Sportsmobile top
I have now completed construction of my homebuilt 2007 Ford E150 Econoline Van with Sportsmobile Top.
See "Yahoo Groups" / "sportsmobile_owners" group / "Files" / "Terry's 2007 Ford Construction" folder /
"Terry's Ford Narative" file for details of construction.
See "Yahoo Groups" / "sportsmobile_owners" Group / "Photos" / "Terry's 2007 Ford Construction Photos"
for, of course, construction photos.
Back to top
Profile E-mail
Offline
PostPosted: Sat Jun 07, 2008 8:34 pm   Post subject: 2007 Ford Econoline van RV conversion with Sportsmobile top
Photos of my 2007 Ford van
Back to top
Profile E-mail
Offline
PostPosted: Mon Jun 09, 2008 8:29 am   Post subject: Terry's 2007 Ford van construction description & photos
Terry's 2007 Ford E150 Econoline van with Sportsmobile top
I bought the 2007 Ford van new, in late 2007 with the following Factory Options
installed:
4.6 L V8
Trailer Tow Package
Power Door Locks
Power windows
Remote Key less entry
Cruise control
power mirrors
I selected the Ford van over Chevrolet because of the much cheaper cost of the
this Ford van.
I selected the Sportsmobile top over the GTRV top primarily because of build
scheduling. I went to Sportsmobile Texas instead of Sportsmobile Fresno
because, Sportsmobile Texas would install a garagable top on the van, and
Sportsmobile Fresno would not. After I negotiated a early date with
Sportsmobile Texas, it only took Sportsmobile Texas a day and a half to install
the top. Normally it takes a day, but, because I was getting a low profile
powered top, it took more time.
See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "Ford Van Parts List.PDF" file for A list of Parts that I purchased.
As is indicated in "Ford Van Parts List.PDF" file, I purchased several parts from Sportsmobile as follows:
door catches, hinges, battery rack, inlet power cord & connectors, Penthouse
bed, hoop steps, and, of course, garagable "powered" top.
Note - I did not install a propane system, nor a furnace, nor a cook top in
this van. I have found that I do not cook inside. I use a portable 1 burner
stove for heating water. I have, previously had propane furnaces; but, I have
never used them in the van. I do have a portable electric heater. Without
any propane appliances, I had no need for a propane system.
A list of tools that I used in converting the van is as follows: Circular saw,
table saw, saber saw, belt sander, in line sander, "Kreg" pocket hole jig,
electrical drill, screw driver bits, Forsner bits, various clamps, soldering
gun, 48" guide for cutting plywood, 4 metal saw horses, and 4' x 8' x 1/2"
press board used as a layout table.
I started work on the van, in earnest, in early February 2008, right after I
got home from Texas. I did do a little work before the trip. I finished the
conversion in late May 2008.
The first things that I did was remove the back and side door thrush holds in
the van.
I then removed the jack mounting hardware.
I made a pattern/template out of heavy paper for the plywood sub-floor and
the vinyl floor.
I then cut the 15/32" plywood flooring using the pattern/template.
I installed a 100 Amp circuit breaker under the hood wired to the chassis
battery.
I then brought the other end of the electrical
wire to inside the van at the gas fill area.
Sportsmobile installed Penthouse top, and temporarily connected power from
powered roof control switch to electrical wire at inside gas fill area. This
allows me to raise and lower the top during construction.
I then planned the wiring. See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "FORDWIR.PDF" file for the wiring schematic.
I then installed the step hoops.
I then installed the 15/32" plywood sub-floor.
I attached the
plywood to the van sheet metal floor using construction adhesive and
approximately 250 1" x #6 flathead sheet metal screws.
Cut Vinyl flooring.
Design interior layout. See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "FLORDING6.PDF"
Make patterns for side walls.
Cut out driver's and passenger's side 3/32" Oak plywood walls.
I painted all Oak paneling and plywood with Verathane Satin.
Install foam & fiberglass insulation.
Install all walls.
Make patterns for rear side & rear wall panels.
cut out, paint, & Install rear side & rear panels.
wire roof wiring for 110ACV, 12 DCV, from drivers side to passenger side.
wire rear light to passenger side.
Install vinyl flooring. I used double sided tape at front back door and side door.
Make pattern for bench seats.
I used the "Kreg" pocket hole jig and screws for fastening all bench seats,
cabinets, and doors.
In addition, I used
wood glue for all joints.
Build bench seats. I used 15/32" Oak plywood for sides.
Install bench seats.
Install outside 110ACV input.
Install converter.
Install battery separator on drivers side, under bench.
Design drivers-side rear, front, and middle cabinets.
See “Yahoo Groups” / “Sportsmobile_owners” group / "ACREF2.PDF" , "MIDCAB.PDF" , AND "POTTI3.PDF" for drawings of these cabinets.
I then made a template/pattern for cabinet sidewalls.
I then made the 15/32" Oak plywood cabinet sidewalls.
Make the three drivers side cabinets.
Install the three cabinets.
Make template, cut out & install passenger side mount for battery meter, 12dcv
receptacle, 110 ACV receptacle, & pump switch.
Install 110acv receptacle & 12 dcv receptacle in drivers side bench. Install
110acv receptacle in passenger side bench.
Wire drivers side AC inlet, 110acv receptacle, DCV receptacle, front light,
converter, battery separator.
Wire passenger side AC receptacle, DCV receptacle, light, trimetric meter,
water pump.
Make cabinet doors.
Another technique that I have used to
finish edges of the Oak plywood is to use a very thin veneer oak with glue on
one side.
This looks better than the 1/2" x 1/2" oak edging that I used on
this van.
install drivers side cabinet doors.
Install floor pedestal plate.
Mount battery rack.
Install 4D AGM battery.
Complete passenger side electrical.
Install "Danhard" Air Conditioning Condenser.
Install A/C Compressor.
Install A/C Accumulator.
Install A/C hoses.
Install A/C Evaporator.
Install A/C Controller.
Wire A/C switches, thermostat, controller, compressor, evaporator, condenser.
Charge A/C
Install A/C trim
Install refrigerator.
Build table & additional plywood to make up bed.
Design Passenger side cabinet. See "Yahoo Groups" / "sportsmobile_owners"
Group / "Files" / "Terry's 2007 Ford Construction" folder / "SINK1.PDF" file
Build Passenger side cabinet.
Install Formica on cabinet, table top, and additional plywood to make up bed.
Install water system.
See “Yahoo Groups” / “Sportsmobile_owners” group / "Files" / "Terry's 2007 Ford Construction" folder / "WATER.PDF" file for drawing
of plumbing connections to tanks.
Build door panels.
Install foam and fiberglass insulation in doors.
Install door panels
Install side door threshold.
Make and install curtains.
Back to top
Profile E-mail
User avatar
Offline
PostPosted: Mon Jun 09, 2008 2:34 pm   Post subject:
Thanks for posting all your details.
What costs do you think you saved by DIY?
What weight do you estimate you DIY SMB is? I always felt that SMB has cabinets, flooring, insulation that adds too much weight.
what's next?
___________________
Thanks, Marty
Marty's 'BearsMobile'
1995 Dodge SMB EB-20 + modified for shower in back, PH Microlite Starcool. 130k miles young!
Back to top
Profile E-mail
Offline
PostPosted: Mon Jun 09, 2008 4:40 pm   Post subject: My 2007 Ford van hone built RV conversion
I added $15,000 cost in parts and tools for converting my van. This includes sales tax. The 2007 Ford van cost $19,800. A new RB12 costs $17470. Penthouse bed is $398. Danhard A/C is $2335. Porta Potti is $125. Powered low profile Penthouse top is $6500. There would be a $900 credit for no propane nor stove. The total is $25,928 plus $1880 tax for the RV conversion. Total is $27808. It looks like I saved around $13,000.on the conversion. However, I do not have as much standard equipment as Sportsmobile.
I do not know how much the van weighs.
Back to top
Profile E-mail
User avatar
Offline
PostPosted: Tue Jun 10, 2008 8:13 am   Post subject: Re: My 2007 Ford van hone built RV conversion
Thanks for the details.
One last Q: How many hours do you think it took?
Also, I would say you saved about $8000 buy using a 2007 van.
Congratulations on the build, it looks great...certainly takes a lot of passion and sweat.
___________________
Thanks, Marty
Back to top
Profile E-mail
Offline
PostPosted: Tue Jun 10, 2008 3:23 pm   Post subject: Terry's 2007 Ford van RV conversion
I did most of my work in Feb, Mar, & Apr 2008. I did some in Jan & May.
In those 3 months, I averaged 6 days a week at 4 hours a day.
I probably have around 400 hours in all. I probably have 50 hours in design and 50 hours in shopping.
I took 10 days to drive to Texas for the top.
Back to top
Profile E-mail
User avatar
Offline
PostPosted: Thu Jun 12, 2008 9:17 am   Post subject:
Impressive build thread. Thanks for posting. Very nice work, by the way. I originally thought about a home brew Sportsmobile, but quickly decided I just don't have the time (marriage is strained enough with buggy mods, motorcycle trailer building and old VW resto project). A home brew SMB would have cost me more in divorce attorney fees, so it just didn't pencil out. Congrats again. You've got a nice well-built ride.
___________________
It takes a village to raise an idiot. You must live in a big city.
Back to top
Profile E-mail
User avatar
Support Bronze
Offline
PostPosted: Thu Jun 12, 2008 9:39 am   Post subject:
Nice!
While I don't have the skills to do it (or the interest), I can certainly appreciate those that do.
Great writeup and pictorial flow.
-Mark
___________________
2008 EB-52, Quadvan 4x4, 6.0 PSD
Back to top
Profile E-mail
Offline
PostPosted: Wed Feb 04, 2009 6:06 pm   Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
I have decided to sell my homebuilt Ford van with Sportsmobile top.
Price $33000 Milage: <15000 miles
terryjones1@hotmail.com
Back to top
Profile E-mail
Offline
PostPosted: Wed Jun 03, 2009 5:13 pm   Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
I have decided to drop the price to $29,900.
Back to top
Profile E-mail
User avatar
Offline
PostPosted: Wed Jun 03, 2009 9:39 pm   Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
Good job, I'll be starting ours in a little over a week, were really excited to get started (on the interior) so we can be finished & using our creation! Keep the pic's coming and your parts list (If you don't mind).
Enjoy
___________________
Cheers,
Jamie
2006 E350 Quigley 4x4, building the conversion with the gracious help from the people on this awesome forum!
I'll try & post all of our progress on our family dream, when we have some.....
Back to top
Profile E-mail
Offline
PostPosted: Thu Jun 04, 2009 9:10 am   Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
go to:
Yahoo Groups > Sportsmobile_owners Group > Files > Terrys 2007 Ford Construction
You will find lots of information on my van, including a parts list.
Back to top
Profile E-mail
User avatar
Offline
PostPosted: Mon Aug 24, 2009 1:22 pm   Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
nice job, van, and pics ... blkjak ... :a4:
___________________
Image 05 e-250 extended crew cargo van to be converted to sleeper...
Back to top
Profile E-mail
Offline
PostPosted: Tue Aug 25, 2009 10:24 am   Post subject: Re: Home built 2007 Ford E150 van with Sportsmobile top
I have decided to drop the price, again, on my 2007 Ford van with Sportsmobile top.
The new price is $27,900.00
Back to top
Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
