Old 12-13-2014, 01:43 PM   #1
Espar D2 Install Thread?
Has anyone installed a Espar D2 and documented it either here or elsewhere; having a tough time finding info in this install.
Old 12-22-2014, 07:52 AM   #2
Re: Espar D2 Install Thread?
Wow, nothing eh? One question that someone may be able to answer: do I need to drop the fuel tank and tap into that or can I tee off of the fuel line prior to the inline pump?
Old 12-22-2014, 01:40 PM   #3
rockbender's Avatar
Hi Taylor,
I T'd off my line prior to any fuel pump and it worked just fine. The Espar fuel pump needs to sit at a certain angle to function properly if I remember correctly - make sure you look into that. Also make sure that you use adequately sized wire since it has a decent draw while the glowpin is lit.
I'll look back to see if I took any pictures along the way that may be helpful.
cheers,
josh
Josh
Old 12-22-2014, 06:37 PM   #4
Thanks Josh; that is just the info I was looking for!!!
Old 12-27-2014, 11:33 PM   #5
The exhaust and intakes must be done correctly as well.
Old 12-27-2014, 11:43 PM   #6
You may search over on the Sprinter Source forum, lots of threads over there detailing install...
frostyone is offline   Reply With Quote
