Old 04-21-2015, 06:27 AM   #1
Sofa Bed With Seat Belts
Anyone know where to find a high quality sofa bed with belts for a EB50 style layout?
Old 04-21-2015, 09:21 PM   #2
Re: Sofa Bed With Seat Belts
I found one in a Chateau Chevy conversion headed to a junkyard. I got it for cheap and redid the foam and a buddy of mine with an industrial sewing machine covered it for me. Turned out great, I might have 200.00 into it all said and done. You can also check out some of the vw sites, they sometimes have things pop up that will work.
Old 04-21-2015, 11:05 PM   #3
rockbender's Avatar
There are certainly options out there for used (craigslist, junkyard) and new sofa seats (check out discountvantruck online), but I'm not confident that many have the seat belts built into them. My best guess is that often the mounting hardware and/or seat frame is not up to par with what would pass the required safety standards. Perhaps others can chime in on their configurations.
What you most likely will want to do is get a sofa seat and then independently install the seat belts through the body/floor with adequate plate washers or other hardware to prevent the bolts from pulling through the sheet metal. What I have done in the past is mount a piece of unistrut to my floor so that I have some flexibility in seat belt placement - YMMV.
Seat belts are always a touchy subject - good luck!
Josh
Old 04-22-2015, 06:20 AM   #4
Great info from both of you guys; thanks!
I knew that seatbelts can be touchy, just wanted to see if there any options out there I didn't know about.
Old 04-22-2015, 11:14 AM   #5
wadewaydo's Avatar
I used this sofa bed. You can order it with seat belts.
http://www.discountvantruck.com/rvva...ansofabeds.htm
Seat belts available:
http://www.discountvantruck.com/rvva...nseatbelts.htm
Wade
1995 Econoline E-150 Custom Campmobile "Jupiter I" RB, 4wd Dana 60s, 93 Eurovan poptop.
1976 VW Type II Transporter Westfalia Campmobile.
1994 Toyota 4Runner,2001 Ford Escape,1970 Chevy El Camino,2 Cargo Trailers, 5 bikes, 4 Kayaks, 1 Canoe
wadewaydo is offline   Reply With Quote
