Old 02-16-2009, 05:50 PM   #1
LeadDoggy's Avatar
Overhead Console (Split)
Completed and installed custom Overhhead Cab Module
07 E350, Custom and Lifted
08 Harley Davidson Street Glide
09 KTM EXC 530
LeadDoggy is offline   Reply With Quote
Old 02-16-2009, 06:57 PM   #2
JoeyNick's Avatar
Re: What work did you do on your SMB today?
Nice job. How did you mount the module?
Old 02-17-2009, 06:45 PM   #3
LeadDoggy's Avatar
Used the mounting brackets from an overhead shelf kit. The shelf kit was very shallow and I did not like the way the visors mounted to it.
update: check gallery for updated photos
09 KTM EXC 530
Old 02-18-2009, 03:47 AM   #4
JoeyNick's Avatar
Do you have pictures and/or description of how it's mounted?
Old 02-21-2009, 11:19 PM   #5
JoeyNick's Avatar
Thanks for the pic LeadDoggy!
Old 02-22-2009, 10:28 AM   #6
Re: Overhead Console (Split)
This is turning into more of a project discussion so I split it out of "what I did today". Good info!
Old 02-22-2009, 10:44 AM   #7
LenS's Avatar
Looks very clean and professional. What is located to the left (square hole in wood) of the driver in the overhead? Also what is the material you covered it in? Again, very nice looking job.
Len & Joanne
The Green TARDIS
Old 02-22-2009, 05:36 PM   #8
LeadDoggy's Avatar
Located in the square hole on drivers side is two toggle switches mounted on 1/8" aluminum plate and covered with carbonfiber tape. switch on left controls the Daytime Running Light disable and the other presently has no function. The cab module was covered in your standard speaker box covering material
09 KTM EXC 530
Old 03-01-2009, 09:18 PM   #9
it does look good. how well do the visors work when you rotate them to cover the left/right windows?
Joe Skrivan
E-350 V-10; Penthouse, Custom Interior
skrivan is offline   Reply With Quote
Old 03-03-2009, 07:22 AM   #10
LeadDoggy's Avatar
Visors work well to cover windshield! They are low be not low enough to cause problems. They will hit the rearview mirrow and knock it out of adjustment and block view, but that's what the outside mirrows are for......
09 KTM EXC 530
