Old 06-16-2014, 06:42 PM   #1
LS and/ or Lockers
If I have the rear ARB lockers installed, isn't my SMB rear end still Limited slip when the rear lockers are not engaged?
Frank
Sffranky
SFfranky is offline   Reply With Quote
Old 06-16-2014, 07:32 PM   #2
oldbonesclimber's Avatar
Re: LS and/ or Lockers
Nope, Open Differential when Not Engaged.
Paul
Old 06-16-2014, 09:55 PM   #3
Now it begins to make sense. It's question of LS only or OD/locker.
I kept wondering why someone wouldn't want both....
Frank
Sffranky
Old 06-20-2014, 02:42 PM   #4
I ended up going with limited slip differential.
Thanks for the enlightenment oldbonesclimber.
Frank
Sffranky
Old 09-06-2015, 08:36 PM   #5
Im pretty sure Eaton E lockers are limited slip then full locker when engaged.
windyhill is offline   Reply With Quote
Old 09-06-2015, 09:40 PM   #6
LS and/ or Lockers
In my Jeep I have an Auburn Ected "locker". It is a limited slip when it's disengaged and it's a much tighter limited slip when it's engaged.
I wouldn't call it a true locker because I can (and regularly do) make one wheel spin freely even when it's engaged but it does work well enough.
ert01 is offline   Reply With Quote
