Old 09-23-2014, 09:18 PM   #1
Zeta's Avatar
HD Spring Shackles
I had a rear shackle fail on me today. The other side is cracked too. I guess the Ford shackles are prone to this. Any heavy duty options out there? Should I have known about this?
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 09-23-2014, 09:32 PM   #2
Re: HD Spring Shackles
Thought you had Deaver's???
Old 09-23-2014, 10:22 PM   #3
Zeta's Avatar
I do.
Z
'06 RB50 SMB Diesel
Old 09-23-2014, 10:35 PM   #4
I don't know how they fit with Deavers, but I really like these:
http://www.sulastic.com/sulastic
They primarily isolate harshness, however they do not make the ride "plush" (but that's what you have Deavers for anyways ).
I've had mine on for a while now. I think close to 200,000 miles. The rubber torsion isolator is finally sagging enough I'll probably update them with a new set soon, since they hit the stops when loaded heavy which makes them ride like a regular shackle. They are definitely robust.
Old 09-23-2014, 10:37 PM   #5
ANZAC's Avatar
I put new OEM shackles on when I put my Deavers on, figure they'll give me another 10 years.
Sportsmobile-less.
Old 09-23-2014, 10:45 PM   #6
Originally Posted by Zeta
I do.
Z
Now you're gonna make me look. Hope it isn't a Deaver thing.
Old 09-23-2014, 10:46 PM   #7
I figured Deaver replaced them when they did the job. No?
Old 09-23-2014, 11:39 PM   #8
ANZAC's Avatar
I gave new OEM shackles and bolts/nuts to Deavers because mine were incredibly rusty. I don't know if they normally replace them.
Sportsmobile-less.
Old 09-24-2014, 12:07 AM   #9
BajaSportsmobile's Avatar
Improper installation will shorten their life. Bolts should be left loose until that vehicle is at ride height and the springs are carrying the load, then they should be tightened in that neutral position.
Thicker leaf packs like Deaver or National will not torsionally twist as easily as stock springs and will transfer the torsional loads to the spring hangers and shackles when the axle articulates.
When I race Stock Full Trucks, these were replaced after every race.
Old 09-24-2014, 11:09 AM   #10
Zeta's Avatar
Good stuff. Thanks. Think the Sulastic shackles would aid articulation?
Z
'06 RB50 SMB Diesel
