Old 10-27-2014, 10:30 AM   #1
Lube level in front diff?
When I take the plug out of the front differential, should there be enough gear lube in it to just ooze out the hole? As it is, it's about 1/2 inch below the hole.
And what's the best way to top it off it it's low. This is the first time in 70k miles, and a couple lube changes it's been below the level of the hole.
thanks....
flyfisher is offline   Reply With Quote
Old 10-27-2014, 11:50 AM   #2
Tapatio's Avatar
Re: Lube level in front diff?
Assume you have dynatrac pro rock 60? Instructions in link.
http://www.dynatrac.com/pdfs/Oil-Fill-Procedure.pdf
Callsign KK6GIY
Old 10-27-2014, 10:13 PM   #3
BajaSportsmobile's Avatar
thanks....
It won't change the volume unless there is a leak or it is coming out the vent. In either case there would be a mess somewhere.
Old 10-28-2014, 11:11 AM   #4
Any suggestions on the best way to top it off? The Van isn't due for service for several months.
thanks...
Tom
Old 10-28-2014, 11:20 AM   #5
Tapatio's Avatar
1/2" below the hole is nothing to be concerned with and probably where it needs to be. The diff is a closed system so unless you have a leak there's no reason to top off.
I filled my rear to be level with the hole and it squirted stanky grease out the vent pipe for a few weeks, really nasty mess.
If you don't agree it won't do any harm. Funnel and tube would do the job or just squirt in from a bottle.
Callsign KK6GIY
Old 10-28-2014, 12:55 PM   #6
Thanks for the tips, no need for skanky messes, I'll leave it just like it is.
Old 11-01-2014, 07:53 AM   #7
REF
REF's Avatar
Send a message via MSN to REF
When having my unit bearings swapped out for dynatrac's free spin hub kit, Derek found there was diff fluid in the axle tube, my inner seals needed replacing, something to consider. I think we also found water in the tubes that got in there after forging all the flood waters we had here last fall=outer seals.
