Old 05-15-2015, 06:51 PM   #1
01 E250 Ex. Cargo Conversion
Could anyone tell me what donor truck is best for a 4x4 conversion on my 01 E250. Unfortunately I do not have the means to buy everything from UJOR or any of the other conversion companies. Will a factory leaf shackle off a similar year F250 fit the E250 I have some mechinical ingenuity tools welders torches etc. How do I make this happen. If I have to buy some parts online so be it but there are many junk yards near me with plenty of stock in fords. I am looking for the final result I am looking for is a 6 inch lift with a dana 60 up front, fix the one wheel burnout in back keeping the factory D60 adding a locker. I need a donor t case, mounts, any info on trans mods needed for 4x4 conversion, drive shaft info, shock mounts, locations for mounts brackets etc, and what not to do. So far I have only been upgrading the interrior and it is coming along great. Any help would be great. Thanks guys!
bkspire1989 is offline   Reply With Quote
Old 05-20-2015, 10:06 PM   #2
Re: 01 E250 Ex. Cargo Conversion
Old 05-25-2015, 04:36 PM   #3
Check out ujoint's website. Tons of great info with plenty of options for you to buy/supply you own parts for the conversion.
http://www.ujointoffroad.com/4x4vanfaqs.html
01 Eurovan Weekender
04 E350 rb V10 Wigley
macdadmorgan is offline   Reply With Quote
Old 05-25-2015, 08:04 PM   #4
BajaSportsmobile's Avatar
I would go with 2005 on up F250/350 front axle and suspension - like QuadVan does.
Used parts are easy to come by and the conversion is pretty simple. QuadVan may sell the brackets or I think Colorado Camper Van may have something - or make your own.
You could use the rear axle out of the same truck or wheel adapters and keep your rear axle.
Old 05-26-2015, 08:25 PM   #5
UJOINT's Avatar
Wish there was an easy way but if factory parts fit the E series correctly I wouldn't be in business!
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
