Old 07-21-2015, 07:57 PM   #1
UJOINT's Avatar
06 SMB 4x4 with some mods
We recently made some mods to this rig. Customer wanted rear bags and our kit only works with a 6" spring so we weighed the van and had new springs made front/rear. Added a bit of lift and we kept the front dims the same from SMB (our springs are a bit longer and move the axle forward) Fox 2.0's all the way around, new wheels & tires (XD Addict with Toyo RT's, 35's) and we clocked the oil filter to get it away from then front shaft. New brake lines, extended the sway bar links, drives better with the new setup.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-22-2015, 09:26 AM   #2
audisnapr's Avatar
Re: 06 SMB 4x4 with some mods
Looks badass, Chris.
4amRacing
audisnapr is offline   Reply With Quote
Old 07-22-2015, 08:24 PM   #3
UJOINT's Avatar
Thanks. It will be back at some point for some engine and brake mods.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-24-2015, 08:28 AM   #4
cmyoung's Avatar
Nice work! Can you elaborate on rotating the oil filter? I have a clearance problem on my '06 diesel.
cmyoung is offline   Reply With Quote
Old 07-24-2015, 09:38 AM   #5
UJOINT's Avatar
Sure. We clock it like this
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
