yakhlr - Creston, CA
Login FAQ Search It
Register
Sportsmobileforum.com
An online forum community for the owners, admirers and fans of Sportsmobile vans and Sprinters, new and old. Share photos, advice, discuss modifications, camping or buy & sell. Anyone who owns, has a passion for, or just curiosity about SMBs, come in!
The time now is Tue Sep 07, 2010 6:46 pm
View unanswered posts
View active topics
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Author Message
User avatar
Support Bronze
Offline
PostPosted: Fri May 11, 2007 1:48 pm   Post subject: driving with the brake
When you have one wheel in the air (with an open differential), by applying a little brake and gas at the same time, you're increasing the amount of torque that can be applied to that wheel in the air. With the brake applied, it takes more torque to turn a wheel in the air. (It otherwise takes essentially zero torque to spin that wheel.)
Because an open differential always sends equal torque to both wheels, when you apply the brake with the gas, the wheel on the ground now also gets some torque, too -- the amount depends on just how much you press the brake.
-- Geoff
___________________
2004 Ford, SMB 4x4, RB-50, gas v-10
http://octopup.org/sportsmobile
Back to top
Profile E-mail
User avatar
Support Gold
Offline
PostPosted: Fri May 11, 2007 3:45 pm   Post subject:
Having just returned from the SMB factory, I discussed this issue with them and got the opinion that in most cases, with the SMB 4x4, the ARB front locker working with the stock limited slip rear is sufficient. Most of the rigs they sell are equipped like that, and most of the off-road-ready finished vans I saw were the same. So I went with that configuration myself.
___________________
Back to top
Profile E-mail
User avatar
Offline
PostPosted: Mon May 14, 2007 10:28 am   Post subject:
Jeffrey wrote:
Buji,
Unless I misunderstood, you are referring to lockers, but talking about manual locking front hubs. Two different things.
No you're right, I was spacing. I don't think anyone wants to crawl under a vehicle to engadge a manual differential!
Eaton is also manufacturing electronic locking differentials, but I'm not sure if they have an fitment for the this type of application.
___________________
-Buji
_________________________
Back to top
Profile E-mail
User avatar
Admin V
Offline
PostPosted: Mon May 14, 2007 11:00 am   Post subject:
There are electric lockers available for the Dana44 and Dana 60, and there are also OX lockers, which are cable activated. Both are alternatives to ARB if you don't want to run air but still want selectable.
There is also the option of putting in a regular full-time locker, and the Jeep guys swear that you can't tell there is a Detroit in a front axle when you're in 2wd, but I'm still leery of doing this.
Also with a locker engaged in an axle, when the tires break traction, there is nothing preventing sideways motion and the axle whichever direction it wants. Whereas with an open diff, limited slip (usually), or an deselected locker, the wheel not under complete power will provide tracking, so while you may not go forward or back, you also won't be as likely to just go sideways.
Having had experience I'd rather drive on snow and ice open than with lockers.
Back to top
Profile E-mail
Support Bronze
Offline
PostPosted: Sun May 20, 2007 8:10 pm   Post subject: Lockers vs limited slip
We got a limited slip on the rear and ARB locker on the front of our van. I once had a Bronco with limited slips on both ends, and the front end had a nasty tendency to refuse to turn on slippery surfaces. Being able to totally unlock the front diff allows equal torque distribution to each wheel for most situations, while having the option of locking them together if you're really stuck.
The locker saved me an expen$ive tow when I had my van less than 2 weeks and got the right side wheels into the snow berm at the side of the road during a whiteout. With the axle unlocked, the right front wheel just dug itself deeper, while the left didn't pull. Locking the front axle allowed driving out.
John Tarr
Back to top
Profile E-mail
User avatar
HobbyistVendor
Admin V
Support Bronze
Offline
PostPosted: Fri May 25, 2007 8:40 pm   Post subject:
kzemach wrote:
Hey, can you explain more about this? Is this what the miltary refers to as "brake-throttle modulation"?
I was totally blown away by what we could do in a HMMWV: driving up out of right angle stream bed with a height of at least 3'... we'd literally be balancing on the RF and LR wheel with the other two wheels totally, way off the ground, and could move forward and backwards just fine. To do it, you'd start with the brake engaged while in drive. Then give it some gas, then slowly let off the brake until you were moving, and drive with both the accelerator and the brake pedels depressed. Worked like a charm. The guy who was showing me how to do it said something about there being a danger in quickly releasing the brake during this operation, as it could do some sort of damage, but all that explanation was lost on me; I'm not much of a gear head.
So, is this the same thing, or is there something in the HMMWV that's different?
It's a type of limited slip differential that has a clutch-pack in it, that with the brakes applied at least partially, tightens up more and more until it's almost fully locked. Cheaper and easier than an ARB locker but not as versitile IMO.
___________________
'06 E350 EB, PSD, SMB 4x4, e-penthouse, Aluminess f/r bumpers, Hellas (3 HID's, 2 driving lights, backup lights, rear work lights), 5 Captain's chairs, bench seat (or rear bed), small galley unit, Kyocera solar panel & BlueSky controller, Sirius radio, Navigation, Extreme Air compressor, Mag Hytec trans pan, BD Power X-Monitor, Banks exhaust, bypass oil filtration
Back to top
Profile E-mail
User avatar
HobbyistVendor
Admin V
Support Bronze
Offline
PostPosted: Fri May 25, 2007 8:42 pm   Post subject:
Sorry for responding to myself, but I didn't qualify my answer. I'm familiar with a civilian-market differential like I described, and I ASSUME the military system is similar, but I don't know that for a fact.
___________________
Back to top
Profile E-mail
Offline
Location: Kandahar, Afghanistan (usually in California)
PostPosted: Tue May 29, 2007 9:24 am   Post subject:
You're probably correct: my understanding was that the H1 was essentially the same, at least for the functionality of the drive components. Thanks for the clarification on the question; I really don't know jack about drive systems so this is all very new to me.
Back to top
Profile E-mail
Display posts from previous:  Sort by
Who is online
Users browsing this forum: Bike and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
