So I just bought this 97 quigley E250 5.4 in Baltimore...only problem is I live in Los Angeles.
I'm flying out next week to drive it 2,700 miles back. The van has 180k and a solid case of the dw according to my friend who picked it up for me.
I'LL HAVE A FULL OPEN CARGO SPACE IF ANYONE WANTS HAVE ME BRING PARTS OUT TO THE WEST COAST
I'm gearing up for a quick day of maintenance in baltimore before I hit the road and wanted to see if there is anything i'm missing in terms of service and replacement.
Current List of Service/Parts/Tools:
Drive Train:
Change oil and replace with Valvoline Max Life
New Plugs
New Wires
New Air Filter
New PCV Valve
New Fuel Filter (if there is an inline frame mounted one)
Run Diagnostic to Check for Codes
Have Trans Serviced/Flushed
Check U-Joints and Repair if Worn (otherwise carry spares)
Check All Other Fluids
Suspension/Brakes
Replace Track Bar Bushings
Replace Front and Rear Shocks with Bilstein 5100's
Might Get an Alignment
Replace Steering Stabilizer if Time and Ability to Source one Permits (anyone know a bilstein PN?)
Replace Inner and Outer Wheel Bearings
Replace Brake Pads (know they are worn)
Check Ball Joints and Tie Rod Ends
Spanner Check Suspension Mount Bolts
Tools
Large Socket Set
General Assorted Tool Box
D44 Hub Tool
Code Scanner
BFH, Zip Ties, Bailing Wire, Duct Tape & Tie Downs
Sleeping Bag & Bottle of Whiskey
Any other thoughts? I know I'm probably forgetting something.
Thanks.
Tim
