Old 11-27-2012, 08:08 AM   #1
Pschitt's Avatar
Search on Craiglists all over the USA ?
Hello guys !
Could somebody tell me if it's possible to search for vans on craiglists not only by state/region but all over the USA ?
Thank you for helping a Swiss guy not really aware of how to search on local classifieds...
Old 11-27-2012, 08:48 AM   #2
Re: Search on Craiglists all over the USA ?
webbmac is offline   Reply With Quote
Old 11-27-2012, 08:50 AM   #3
I also use:
http://www.adhuntr.com/
joearlo is offline   Reply With Quote
Old 11-27-2012, 09:11 AM   #4
Pschitt's Avatar
Thanks to both of you!
Old 11-27-2012, 09:17 AM   #5
dhally's Avatar
I like searchtempest.com
2009 E250 RB 5.4L "SilVan"
Old 11-27-2012, 09:24 AM   #6
Pschitt's Avatar
Thanks dhally !
Old 11-27-2012, 09:37 AM   #7
+1 for SearchTempest.com
You can also output specific searches from there as RSS feeds and dump them into your newsreader. I have a SMB one set up that way, which is how I found my van in North Carolina (I'm in PA).
Old 11-27-2012, 09:46 AM   #8
Pschitt's Avatar
Thanks Brian!
Old 11-27-2012, 01:12 PM   #9
Viva's Avatar
An additional note when using Google to search a specific site (e.g. blahblahblah site:craigslist.org). If you just run that search, you'll get results from now, results from years ago, results from months ago, etc. Not always what you want if searching to buy something for sale now. But if you go to "search tools" (after you run the initial search), then select "any time," a drop down sub-menu will allow you to select "past 24 hours," "past week," "past month," etc. Or you can then put in your own custom range.
Viva
Old 11-27-2012, 03:34 PM   #10
Pschitt's Avatar
Thanks for this trick Viva !
Dodge
lugee
EB Van
ebflow
