Old 03-30-2015, 04:57 PM   #1
2000 Ford Econoline E350 EB V10 4x4
I pulled this off Craigslist San Diego
2000 Ford Econoline E350 EB V10 4x4 - $19500 (Poway)
2000 Ford Econoline e350 odometer: 117000 paint color : custom size : full-size type : van drive : 4wd fuel : gas transmission : automatic title status : clean cylinders : 10 cylinders
condition: good
PRICED TO SELL
2000 Ford e-350 EB V10 4x4
One of a kind, V10 motor, less noise than the diesel and will last as long.
Seats 4 + passenger and third seat swivels, benches open for extra storage, 10 gallon water on board, outside shower (no hot water, did not install a water heater but one can be easily added). Tires have less than 2k on them and are 35's. When I bought this last year I had the motor, transmission, transfer case, rear end and break system gone over. All fluids changed, plugs wires, hoses that need it, new brakes, rotors and calipers, transfer seal case replaced and had transmission checked when it was apart.
Custom built benches with rail for wood slates which turns into a bed with room for storage under. Ideally I wanted to get cushions made for the benches that would fold out to cover the slates.
I have receipts for all work and all items purchased, similar to a sportsmobile but all custom work.
I added 2 Captain Chairs (Driver and Passenger from a 2009 Ford Econoline, after that the airbag light stayed on. Not sure what is causing this, it worked before I swapped out the seats.
Salem Kroger 4x4 Leaf Spring conversion
117k
New Rotors, Breaks and Calipers
All fluids changed
K&N Air filter
Transfer case seal replaced and transmission checked
Porcomp steering stabilizer
New plugs, filters, cables, etc
5 tires -- Maxxis Bighorn -- 315 -- 75 - 16 less than 2000 miles on them
Exterior
Aluminees ladder
Aluminees rear tire rack
Brand new front and rear bumper
10000 lb rear tow hitch
Custom roof rack
100 watt Solar panel
2 LED lights
1 motion sensor LED light
Enclosed shower
2x Deep cell battery
PA speaker
30 amp shore power
Interior
Interior just completed
Captain chairs out of a 2009 Econoline
Passenger and rear swivel seats
4 Led lighting strips with wireless remote control
Fantastic Fan
Uniden CB
Kenwood VHF TM-281
Pioneer DDX-370 DVD player stereo -- USB connection and AUX jack
Backup camera system attached to Pioneer
10 gallon water tank with Flojet water pump
Under floor storage where spare tire was
Benches covert to queen size bed
Misc included
Heavy duty tire chains (never used)
3 ton floor jack
Lug break
Receipts for all work done and all items purchased.
Clean car fax -- will email on request
I am the second owner of this vehicle
CA Title in hand
No major rust
Normal scratches and dents
FAT-Mat noise reduction on all flooring and doors
Insulation on al walls ceiling
Blues sea fuse box
Blue sea switch to change between starting battery and solar battery.
Solar is wired to power the following but they all can be switched to be powered by starting battery: VHF, CB, LED Driver side & rear light, Shower pump, Fantastic Fan, LED interior light bars and LED motion light.
atillathedan is offline   Reply With Quote
Old 03-30-2015, 05:10 PM   #2
Re: 2000 Ford Econoline E350 EB V10 4x4
Pics or CL link?
Thanks
Old 03-30-2015, 05:12 PM   #3
rallypanam's Avatar
Deleted by author:
http://sandiego.craigslist.org/csd/cto/4952780627.html
Old 03-30-2015, 05:25 PM   #4
mikracer's Avatar
I thought I recognized the description of the van. It's Shadzima's van... Great looking van and I'm surprized it hasn't sold. Below is a link to an old ebay ad.
http://www.ebay.com/itm/2000-Ford-E-350 ... 55?vxp=mtr
Old 03-30-2015, 05:39 PM   #5
well I guess I'm busted.
I actually did buy this van and was trying to see what kind of a deal I got by an unbiased audience (not that you guys are biased but you typically get a different response before you buy than after)
first time on any of this stuff.
this link should work for pics
https://www.dropbox.com/sh/vcyeuzzfw...TBqTZ9DNa?dl=0
Its definitely fun so far..
Old 03-30-2015, 06:55 PM   #6
mikracer's Avatar
Its definitely a sweet van. I think for the price, you got a pretty good deal. I never saw the van in person, but from the pics it looks like its in great shape and ready for whatever.
Old 03-30-2015, 08:17 PM   #7
Viva's Avatar
Congrats and welcome (but yeah, maybe a more direct question next time )
Van looks neat - I'm always attracted to those sort of industrial/transformer looking interiors.
One note from something I saw in the ad:
"I added 2 Captain Chairs (Driver and Passenger from a 2009 Ford Econoline, after that the airbag light stayed on. Not sure what is causing this, it worked before I swapped out the seats."
I don't know if you know this or not, but at least on my 1997, if the airbag light is on, that means the whole system is disabled - so no airbags in a crash. If that'd be fine with you, no big; but I just thought I would mention it in case you were not aware.
You may see a series of flashes when you first start the van. If so, that's a clue. It will be a pattern of two "digits" (at least is on my '97), repeated three times, then the light comes on solid. The codes are different from OBD codes, but you can look them up online.
I'd want to get that working again.
Old 03-30-2015, 08:40 PM   #8
good tip on the airbag light the seller did mention it coming on when he installed the chairs - Ill check those codes
